Building project - Eclipse
Tue Mar 13 14:45:55 UTC 2012
On 03/13/2012 03:21 PM, Binkowski, Cassio wrote:
> On Tue, Mar 13, 2012 at 8:42 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 03/13/2012 02:39 PM, Binkowski, Cassio wrote:
>         On Tue, Mar 13, 2012 at 7:50 AM, Sebastian Huber
>         <sebastian.huber at embedded-__brains.de
>         <mailto:sebastian.huber at __embedded-brains.de
>         <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>             On 03/13/2012 01:26 PM, Binkowski, Cassio wrote:
>                 Ok. I did it.
>                 Rebuilt it with the prefix and did a "make install".
>                 Eclipse configuration:
>                 Base path: /opt/rtems-4.11
>                 BSP path: /home/rtems/build/sparc-____rtems4.11/sis
>             What is "the prefix"?
>         Prefix is the following:
>         --prefix=/home/rtems/build/__sparc-rtems4.11/sis
>         Is it wrong?
>     It is not wrong, but in this case the BSP path is
>     /home/rtems/build/sparc-rtems4.11/sis/sparc-rtems4.11/sis
> I'm afraid that inside:
> /home/rtems/build/sparc-rtems4.11/sis/sparc-rtems4.11/sis I only have the /lib
> folder.
> Is this a sign that it went wrong?
Yes, something is wrong.  The
/home/rtems/build/sparc-rtems4.11/sis/sparc-rtems4.11/sis directory should
contain more, e.g. a Makefile.inc file.
Can you please post all commands which you executed to produce the SIS BSP.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
