./bootstrap problem!!
Binkowski, Cassio
cassioiks at gmail.com
Fri Mar 16 13:26:27 UTC 2012
On Fri, Mar 16, 2012 at 10:21 AM, vai bas <vai.csse at gmail.com> wrote:
> I have cloned from the git clone git://git.rtems.org/rtems.git rtems and
> found the bootstrap and got success. But again I have not found in top of
> repository to do following steps:
> Configure and build
> $ cd ..
> $ mkdir b-rtems-4.9-testing
> $ cd b-rtems-4.9-testing/
> $ ../rtems-cvs-20080911/configure --enable-rtems-debug \
> --target=powerpc-rtems4.9 --enable-posix --prefix=/opt/rtems-4.9 \
> --enable-networking --enable-cxx --enable-rtemsbsp="virtex" --enable-maintainer-mode
> $ make all
> There is not any configure file inside of rtems cloned from given link
> above. my process and error :
> ../rtems/configure --enable-rtems-debug \ --target=i386-rtems4.11
> --enable-posix --prefix=/opt/rtems-4.11 \ --enable-networking --enable-cxx
> bash: ../rtems/configure: No such file or directory
This is a reference path. It assumes you're inside the folder you want to
build RTEMS and this folder is in the same level as the RTEMS source folder.
Instead of using "../rtems/configure", try using the whole path. E.g:
"/home/rtems/rtems-work/rtems/configure"
> best regards
> Suresh
> On Fri, Mar 16, 2012 at 5:08 PM, Joel Sherrill <joel.sherrill at oarcorp.com>wrote:
>> On 03/16/2012 07:32 AM, vai bas wrote:
>>> Dear respected users,
>>> Can someone told me about ./bootstrap error? Where can I
>>> found this file? when I did ./bootstrap I found: No such file or directory?
>>> Did someone get this type of error? Thank you as advance..
>>> You are not in the top of the RTEMS source tree.
>>> Best regards
>>> Suresh
>> Joel Sherrill, Ph.D. Director of Research& Development
>> joel.sherrill at OARcorp.com On-Line Applications Research
>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>> Support Available (256) 722-9985
>> ______________________________**_________________
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20120316/ae330360/attachment-0001.html>
