RTEMS shell configuration on 4.8.0
Sat Mar 24 14:14:18 UTC 2012
The shell in 4.8 is in no way comparable to what is in the current code. A significant amount of work occurred after 4.8. There were not many commands and no configuration that I recall.
4.8 is not supported by the free project. It is recommended that you use 4.10 or the git code which will become 4.11
--joel
송영중 <yungjoong.song at samsung.com> wrote:
>Hi,
>I have a problem on the using the shell on the RTEMS.
>My RTEMS version is 4.8.0.
>I found out this documnet ( http://rtems.org/onlinedocs/doc-current/share/rtems/pdf/shell.pdf ) on the internet.
>It explains about the shell on the RTEMS 4.10.99. And there is no document for 4.8.0.
>But I tried to do the section  "1.2 Configuration" on that document, like below
>#define CONFIGURE_SHELL_COMMANDS_INIT
>#define CONFIGURE_SHELL_COMMANDS_ALL
>#include <rtems/shellconfig.h>
>Because there are required source codes and MACROS to configure in the RTEMS 4.8.0 too.
>next, I copied source code from "testsuites/samples/fileio.init.c"
>And little bit modified it like below.
>shell_init("SHLL",RTEMS_MINIMUM_STACK_SIZE+0x1000, 150,"/dev/console",B19200 | CS8, 1);
>And there was no error while compiling it.
>But I stucked on the login process of the shell.
>It asked my ID and PW for login. But I din't set my ID and PW. How can I loggin on that shell?
>I typed "rtems" or "root" as ID and PW but it said that wrong ID & PW.
>Is there any other configuration to use this shell?
>Or can't I use that <Shell> with RTEMS 4.8.0 since it's not supported?
>At least I'd like to disable the function of checking ID and PW.
>Best Regards,
>Yungjoong
