RTEMS support
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Mon Mar 26 18:33:46 UTC 2012
Vai,
the doc page you have found is the right starting point. Actually RTEMS
has no rate monotonic scheduler, but an API to create and use a rate
monotonic timer.
In a task, you can create a rate monotonic timer and, in a loop, wake up
when it expires. After it expired, your task will wake up again and can
perform the next program loop. Then again it can wait for the timer to
expire the next time.
wkr,
Thomas.
Am 26.03.2012 20:23, schrieb vai bas:
> Dear developers and users,
>                I really need some more explanation. Is there
> Rate-Monotonic Scheduling policy in RTEMS? If there is RMS scheduling
> policy then how can i invoke
> this? http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__ClassicRateMon.html
> I found some API here but no where I found about the support in
> scheduling policy. Make me cleare about it please.
> Best regards
> Vai
> rtems-users mailing list
> rtems-users at rtems.org
Embedded Brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax:   +49-89-18908079-9
