Project about Atomic Operations
Ralf Corsepius
ralf.corsepius at rtems.org
Tue Mar 27 07:27:22 UTC 2012
On 03/26/2012 06:19 PM, Thomas Doerfler wrote:
> Hi,
> I am a bit confused about this discussion. I havn't looked into the
> RTEMS/GSOC project related to atomic support, but I agree with Sebastian
> that it doesn't make sense to implement an RTEMS-specific atomic API
> that would replace the C11 standard API.
I agree in sofar as C11 could be a promise about an emerging, future
standard.
So far, IMO, C11 is too young to be considered stable and established
standard and to be utilized as foundation of works.
[Remember how long it took until comparable precessors (c89, c99) were
stable and well established. Their implementation timeframes were
measured in decades - I'd be surprised, if c11 would be different]
> What might make sense is to
> - develop an API for RTEMS synchronization/kernel services which is ON
> TOP of the C11 atomic standard
One option I see, would be to treat c11-atomics as optional and
conditional and to consider their API as API-template for RTEMS specific
atomics.
This would mean, if C11 should be adopted for RTEMS, I'd recomment
RTEMS to implement an RTEMS-specific wrapper layer, which optionally and
conditionally may utilize c11-atomics as one potential implementation
option underneath.
> - develp support routines (maybe in newlib, maybe in RTEMS) that
> implements a synchronization function.
On a wider scope, I think, one would have to analyse whether c11-atomics
actually meet RTEMS demands and ... whether lowlevel atomic operations
are actually necessary and/or useful, rsp. if some atomics aren't better
implemented on higher levels (e.g. using RTEMS score functions).
At least I would rather avoid any low level, RTEMS-specific (esp. ASM)
atomic operations, because such low level code in longer terms often
turns into a nightmare.
> Maybe for the discussion the following wiki page might help:
> http://gcc.gnu.org/wiki/Atomic
> It lists the architectures that GCC directly supports for atomics. All
> other architectures (including ARM, M68K) require library support to get
> atomic operations to work properly. So at least _this_ would be work
> that requires doing.
Well, IMO, The state Atomics in GCC currently is in speaks for itself.
It's an Herculanean effort, which not even the GCC folks are able to
implement on the broadness which would actually be required.
Ralf
