Project about Atomic Operations
Tue Mar 27 16:17:59 UTC 2012
On Tue, Mar 27, 2012 at 4:39 AM, Yang Wei <wei.a.yang at gmail.com> wrote:
> 在 2012-3-27,0:46,Joel Sherrill <joel.sherrill at oarcorp.com> 写道:
>> On 03/26/2012 11:19 AM, Thomas Doerfler wrote:
>>> Hi,
>>> I am a bit confused about this discussion. I havn't looked into the
>>> RTEMS/GSOC project related to atomic support, but I agree with Sebastian
>>> that it doesn't make sense to implement an RTEMS-specific atomic API
>>> that would replace the C11 standard API.
>>> What might make sense is to
>>> - develop an API for RTEMS synchronization/kernel services which is ON
>>> TOP of the C11 atomic standard
>>> - develp support routines (maybe in newlib, maybe in RTEMS) that
>>> implements a synchronization function.
>> I think they are discussed in terms of being libc methods but
>> in reality are provided by the compiler.  GCC 4.7 has initial
>> support.
>>> Maybe for the discussion the following wiki page might help:
>>> http://gcc.gnu.org/wiki/Atomic
>>> It lists the architectures that GCC directly supports for atomics. All
>>> other architectures (including ARM, M68K) require library support to get
>>> atomic operations to work properly. So at least _this_ would be work
>>> that requires doing.
>> Right any atomic implementation done in this project should
>> be fed upstream to gcc and/or clang.  In the case of
>> gcc, that would require an assignment. I can help with that.
>> We have had quick turn around on assignments for GSOC students.
> Yes, it is a little big turn around on assignments for students like me who has almost completed the proposal for this project. Now the period of submitting proposal is beginning, and there are only about ten days for me to complete the proposal. So in my opinion we must determine the direction and the objective of this project as soon as possible. Then I can detail the tasks according to the requirements and modify my proposal in time.
Joel meant copyright assignment required by FSF to push code upstream.
Project proposals tend to be living documents until the deadline, and
changing to meet the needs/expectations of the community should be
expected (even throughout the project).
>> This in addition to wrapping RTEMS primitives on top of gcc atomics
>> which gets us back to something like FreeBSD stdatomics.h. :)
> If we using the compiler built in atomic operations support, we can refer the implementation of FreeBSD.
>>> wkr,
>>> Thomas.
>>> Am 26.03.2012 18:00, schrieb Yang Wei:
>>>> 在 2012-3-26,23:45,Sebastian Huber<sebastian.huber at embedded-brains.de>  写道:
>>>>> On 03/26/2012 05:32 PM, Gedare Bloom wrote:
>>>>>> Maybe we should design our API to be at least a superset of what the
>>>>>> compiler must provide for C11 compliance. Target architectures /
>>>>>> compilers that do not support the C11 atomics will need the atomic
>>>>>> operations implemented in assembly language. For targets that are
>>>>>> supported the API will thinly wrap the C-language atomic features and
>>>>>> can share code.
>>>>> This is reinventing the wheel.  I don't see why we need the 100th atomic library.
>>>> The C11 support for atomic primitive since 2011. Whether the compiler like gcc has support all the atomic primitives and for all architectures? And Rtems does not use standard library provided by compiler, so we still support all the atomic primitives on the newlib. There are also lots of work to do if we support all the atomic primitives defined by C11 standard
>>>>> Sebastian Huber, embedded brains GmbH
>>>>> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>>>>> Phone   : +49 89 18 90 80 79-6
>>>>> Fax     : +49 89 18 90 80 79-9
>>>>> E-Mail  : sebastian.huber at embedded-brains.de
>>>>> PGP     : Public key available on request.
>>>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>> Joel Sherrill, Ph.D.             Director of Research&   Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>    Support Available             (256) 722-9985
