rtems git readonly access behind corporate firewall
    Hill, Jeffrey O
    johill at lanl.gov
    Thu Mar 29 22:27:05 UTC 2012
Hi Again,
I seem to continue experiencing some issues with the rtems git despite some potential fixes to the repository this am, but again I am a git newbie so I could easily be doing something dumb.
The first attempt below is almost certainly caused by the local corporate firewall, whereas the 2nd and 3rd attempt specify http to avoid that issue, but are nevertheless unsuccessful. I did also configure the local http proxy address into the local git client.
hill at ubuntu:~/nios2-rtems/rtems/rtems-git$ git clone git://git.rtems.org/rtems.git rtems
Cloning into rtems...
git.rtems.org[0: 67.63.146.252]: errno=No route to host
fatal: unable to connect a socket (No route to host)
hill at ubuntu:~/nios2-rtems/rtems/rtems-git$ git clone http://git.rtems.org/rtems.git rtems
warning: remote HEAD refers to nonexistent ref, unable to checkout.
hill at ubuntu:~/nios2-rtems/rtems/rtems-git$ git clone http://git.rtems.org/rtems  rtems
error: Recv failure: Connection reset by peer (curl_result = 56, http_code = 200, sha1 = 1c47c470b304bbc6e15c64bdc95749920e94d67e)
error: Unable to find 96ce007eb90e31d841287abdf781c3cfdaa80e4a under http://git.rtems.org/rtems
Cannot obtain needed tree 96ce007eb90e31d841287abdf781c3cfdaa80e4a
while processing commit 9604d8b03c4e791bbcdea2b0125787b8d0a5d5d9.
error: Fetch failed.
Jeff
> -----Original Message-----
> From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On Behalf Of
> Gedare Bloom
> Sent: Thursday, March 29, 2012 12:43 PM
> To: Cláudio Silva
> Cc: Hill, Jeffrey O; rtems-users at rtems.org
> Subject: Re: rtems git readonly access behind corporate firewall
> On Thu, Mar 29, 2012 at 2:37 PM, Cláudio Silva <claudiodcsilva at gmail.com>
> wrote:
> > Hi Jeff,
> > git clone http://git.rtems.org/rtems rtems works for me.
> > There were some problems earlier today in the RTEMS git repository.
> > You probably tried to clone when those issues were being solved by
> > Joel and therefore you got cloning errors.
> > Please try again. It should work.
> > Regards,
> > Cláudio
> > On Thu, Mar 29, 2012 at 7:13 PM, Hill, Jeffrey O <johill at lanl.gov>
> wrote:
> >> Hi,
> >> I am attempting to use the RTEMS git repository but the following
> recommended command doesn't work.
> Also due to the repo being down the usual git clone was not working
> using the git protocol so you might want to retry this as well.
> -Gedare
> >> We have a corporate firewall here so it appears that I am forced to use
> one of the following commands instead (emphasis on http) after configuring
> the proper http proxy in git, but neither of these attempts are
> successful. There is an "rtems" but not an "rtems.git" at
> http://git.rtems.org/.
> >> The first command above results in a the following message.
> >> "warning: remote HEAD refers to nonexistent ref, unable to checkout."
> >> The second command above results in long delays and eventually a
> message about the connection being reset by its peer.
> >> I admit to being a git newbie so maybe someone will immediately
> recognize what I am doing wrong.
> >> Jeff
> >> _______________________________________________
> >> rtems-users mailing list
> >> http://www.rtems.org/mailman/listinfo/rtems-users
