Stale cached data in bdbuf creates problems
ali nasir supremenasir at yahoo.com
Tue May 1 07:20:32 UTC 2012
Hi,
Is the below calls not sufficient to syncand purge all the physical and logical disks?
rtems_bdbuf_syncdev(dev)    //dev is created using the rtems_filesystem_make_dev_t(major, minor)
rtems_bdbuf_purge_dev(dev)
How do we purge all the logical drives? Is there a separate call for the same? or do we have change the argument of the above calls to something else?
Regards,
Ali
________________________________
 From: Sebastian Huber <sebastian.huber at embedded-brains.de>
To: rtems-users at rtems.org
Sent: Monday, April 30, 2012 5:53 PM
Subject: Re: Stale cached data in bdbuf creates problems
Hi,
you have to sync and purge all disks (the physical and all logical) of a driver instance.   The MBR is read from the physical disk.
-- Sebastian Huber, embedded brains GmbH
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
E-Mail  : sebastian.huber at embedded-brains.de
PGP     : Public key available on request.
rtems-users mailing list
http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20120501/8b5dfcb5/attachment.html>
