can--installing can interrupt handler
    Gedare Bloom
    gedare at rtems.org
    Tue May  1 14:58:02 UTC 2012
On Mon, Apr 30, 2012 at 11:24 PM, zhoupeng <zpeng563 at 126.com> wrote:
> Thank you for your answer!
>  As you answer , I can run my test program now! But i can't understand how
> this "interrutp instanll" very well.
>  May I ask  you another question?
> IN my program
> "status = BSP_install_rtems_irq_handler( &can_isr_data );"
>  if( status != RTEMS_SUCCESSFUL)
>     printk("Error installing can interrupt handler!\n");
>    rtems_fatal_error_occurred(status);
> Let's look at some system code about interrupt install.
> IN irq-legacy.c
>  * @deprecated Use rtems_interrupt_handler_install() instead.
> int BSP_install_rtems_irq_handler(const rtems_irq_connect_data *cd)
>   rtems_status_code sc = RTEMS_SUCCESSFUL;
>   sc = rtems_interrupt_handler_install(
>     cd->name,
>     "LEGACY INSTALLED",
>     RTEMS_INTERRUPT_UNIQUE,
>     cd->hdl,
>     cd->handle
>   if (sc != RTEMS_SUCCESSFUL) {
>     return 0;
>   if (cd->on != NULL) {
>     cd->on(cd);
>   return 1;
> irq-generic.c
> rtems_status_code rtems_interrupt_handler_install(
>   rtems_vector_number vector,
>   const char *info,
>   rtems_option options,
>   rtems_interrupt_handler handler,
>   void *arg
>   return bsp_interrupt_handler_install(vector, info, options, handler, arg);
> bsp_interrupt_handler_install will return RTEMS_SUCCESSFUL;
> rtems_interrupt_handler_install will return RTEMS_SUCCESSFUL;
> BSP_install_rtems_irq_handler will return  1;
> status  =  1;  This is not as we expect ( return RTEMS_SUCCESSFUL / 0)
The comments before the function BSP_install_rtems_irq_handler say it
is deprecated so it should not be used. If you are using it then I
suppose you should be aware of this issue.
> At 2012-05-01 01:28:46,"Gedare Bloom" <gedare at rtems.org> wrote:
>>Hi,
>>I can't say much but it looks like you are checking for success by saying
>>if (!status) {
>>  // fatal error
>>which won't work as you expect because RTEMS_SUCCESSFUL is 0. You might try
>>if (status) {
>> // fatal error
>>or better yet
>>if(status != RTEMS_SUCCESSFUL) {
>> // fatal error
>>Good luck
>>-Gedare
> ________________________________
> 网易Lofter,专注兴趣,分享创作!
