MCF5485EVB Board Console problems
Chris Xenophontos cxenophontos at hammers.com
Tue May 1 16:26:43 UTC 2012
thanks so much!
On Tue, May 1, 2012 at 12:05 PM, Thomas Doerfler
<Thomas.Doerfler at embedded-brains.de> wrote:
> Chris,
> we have a Freescale Evaluation board in our company and will
> cross-check your results in the next days (today is holiday in
> germany). Maybe we can help you a bit there.
> wkr,
> Thomas.
> Am 01.05.2012 17:56, schrieb Chris Xenophontos:
>> Thomas, I have the sample applications, but nothing seems to run.
>> I can only get our application to run if I do not enable
>> CONSOLE_DRIVER and use printk.  All startup code, etc built from
>> RTEMS BSP, etc runs as expected.
>> I believe we have the real mcf5484FireEngine board, according to
>> docs that were delivered with the board: dBUG> reset ColdFire
>> MCF548X on the M5485EVB Firmware v4a.1a.1d (Built on Dec  6 2004
>> 11:50:38) Copyright 1995-2004 Freescale Semiconductor, Inc. Enter
>> 'help' for help. dBUG> thanks Chris
>> On Tue, May 1, 2012 at 11:37 AM, Thomas Doerfler
>>> Chris,
>>> can you successfully execute one of the "sample" applications
>>> built for this board, like "ticker.exe" ? These applications
>>> should be present in your "install" tree since you haven't
>>> disabled them explicitly in your configure line.
>>> Are you working with a real "mcf5484FireEngine" board or is it
>>> different in some areas?
>>> Which boot monitor do you use?
>>> wkr, Thomas.
>>> Am 01.05.2012 17:19, schrieb Chris Xenophontos:
>>>> The problem occurs regardless if CONFIGURE_TERMIOS_DISABLED is
>>>> #defined or not. We've repeatedly tried it both ways.
>>>> On Tue, May 1, 2012 at 10:48 AM, Chris Xenophontos
>>>>> is #defined or not. We've repeatedly tried it both ways.
>>>>> On Tue, May 1, 2012 at 10:43 AM, Joel Sherrill
>>>>> <joel.sherrill at oarcorp.com> wrote:
>>>>>> You can't disable TERMIOS and have a working console
>>>>>> driver.
>>>>>> On 05/01/2012 09:41 AM, Chris Xenophontos wrote:
>>>>>>> Hello, In continuing to port a previous application to an
>>>>>>> MCF5485EVB board with RTEMS 4.10.2, We're having problems
>>>>>>> initializing the console. Currently, we successfully
>>>>>>> configured as follows:
>>>>>>> ./rtems-4.10.2/configure --target=m68k-rtems4.10
>>>>>>> --enable-rtemsbsp=m5484FireEngine
>>>>>>> --prefix=/opt/rtems-4.10
>>>>>>> gmake RTEMS_BSP="m5484FireEngine" install
>>>>>>> The problem is that when
>>>>>>> CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER is #defined,
>>>>>>> Either the application is not initializing, or no output
>>>>>>> is sent through serial port.  Only way to get any
>>>>>>> messages to console window is to use printk.
>>>>>>> The snipped below had previously worked as shown, on
>>>>>>> MCF5235 board with RTEMS 4.9 - no issues with console.
>>>>>>> Is additional configuration required for m5484FireEngine
>>>>>>> BSP?
>>>>>>> thanks Chris Xenophontos
>>>>>>> include<stdio.h> #include<stdlib.h> #include<rtems.h>
>>>>>>> #include<bsp.h> #include<unistd.h>
>>>>>>> #include<rtems/rtems_bsdnet.h> #include
>>>>>>> "networkconfig.h" #include "tids.h" #include "pids.h"
>>>>>>> #include "ostasks.h" #include "debug.h"
>>>>>>> rtems_task Init( rtems_task_argument ignored ); extern
>>>>>>> int myAppMain( void );
>>>>>>> rtems_task Init( rtems_task_argument ignored ) { // !!
>>>>>>> forced to use prink - #defining
>>>>>>> CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER won't
>>>>>>> initialize - see below
>>>>>>> printk( "\n\n\nMMS Trainer Initializing...\n" ); printk(
>>>>>>> "\n*** RTEMS Info ***" ); printk( "\n" ); printk(
>>>>>>> "\nsizeof( Objects_Control *):               0x%08X", (
>>>>>>> unsigned int )sizeof( Objects_Control *)); printk(
>>>>>>> "\nsizeof( rtems_name *):                    0x%08X", (
>>>>>>> unsigned int )sizeof( rtems_name *)); printk( "\nsizeof(
>>>>>>> rtems_name ):                     0x%08X", ( unsigned int
>>>>>>> )sizeof( rtems_name  )); printk( "\n" ); printk(
>>>>>>> "\nsizeof(Thread_Control):                   0x%08X", (
>>>>>>> unsigned int )sizeof(Thread_Control )); printk(
>>>>>>> "\nCONTEXT_FP_SIZE:                          0x%08X", (
>>>>>>> unsigned int )CONTEXT_FP_SIZE ); printk(
>>>>>>> "\nSTACK_MINIMUM_SIZE:                       0x%08X",
>>>>>>> STACK_MINIMUM_SIZE ); printk( "\nsizeof(
>>>>>>> RTEMS_API_Control ):              0x%08X", ( unsigned int
>>>>>>> )sizeof( RTEMS_API_Control )); printk( "\n" );
>>>>>>> rtems_bsdnet_initialize_network();
>>>>>>> rtems_bsdnet_show_inet_routes ();
>>>>>>> rtems_bsdnet_show_mbuf_stats ();
>>>>>>> rtems_bsdnet_show_if_stats (); rtems_bsdnet_show_ip_stats
>>>>>>> (); rtems_bsdnet_show_icmp_stats ();
>>>>>>> rtems_bsdnet_show_udp_stats ();
>>>>>>> rtems_bsdnet_show_tcp_stats ();
>>>>>>> #ifdef STACK_DEBUG Stack_check_Initialize(); #endif
>>>>>>> printk( "\nEntering xmain....\n" );
>>>>>>> myAppMain();  /* application, startup, etc */
>>>>>>> exit ( 0 ); };
>>>>>>> #define TASK_INTLEVEL 0 #define CONFIGURE_INIT #define
>>>>>>> CONFIGURE_INIT_TASK_ATTRIBUTES ( RTEMS_FLOATING_POINT |
>>>>>>> RTEMS_PREEMPT | RTEMS_NO_TIMESLICE | RTEMS_ASR |
>>>>>>> RTEMS_INTERRUPT_LEVEL(TASK_INTLEVEL))
>>>>>>> #define CONFIGURE_MAXIMUM_TASKS               20 #define
>>>>>>> CONFIGURE_MAXIMUM_TIMERS               3
>>>>>>> #define CONFIGURE_MAXIMUM_SEMAPHORES          20 #define
>>>>>>> CONFIGURE_MAXIMUM_MESSAGE_QUEUES      24
>>>>>>> #define CONFIGURE_INIT_TASK_STACK_SIZE (10*1024) #define
>>>>>>> CONFIGURE_INIT_TASK_PRIORITY   120 #define
>>>>>>> CONFIGURE_INIT_TASK_INITIAL_MODES (RTEMS_PREEMPT | \
>>>>>>> RTEMS_NO_TIMESLICE | \ RTEMS_NO_ASR | \
>>>>>>> RTEMS_INTERRUPT_LEVEL(0))
>>>>>>> //#define CONFIGURE_MAXIMUM_DEVICES       4 #define
>>>>>>> CONFIGURE_MAXIMUM_DRIVERS              3
>>>>>>> #define ADA_TASKS  0
>>>>>>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE //#define
>>>>>>> CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER    !!!! no
>>>>>>> initialization/console output when defined !!! #define
>>>>>>> CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>>>>>>> // #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM #define
>>>>>>> CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS    4   /* 30 */
>>>>>>> #define CONFIGURE_MICROSECONDS_PER_TICK        10000
>>>>>>> #define CONFIGURE_TERMIOS_DISABLED
>>>>>>> #ifdef STACK_DEBUG #define STACK_CHECKER_ON #endif
>>>>>>> #include<rtems/confdefs.h>
>>>>>>> #define NETWORK_TASK_PRIORITY 80
>>>>>>> _______________________________________________
>>>>>>> rtems-users mailing list rtems-users at rtems.org
>>>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>>>>> -- Joel Sherrill, Ph.D.             Director of Research&
>>>>>> Development joel.sherrill at OARcorp.com        On-Line
>>>>>> Applications Research Ask me about RTEMS: a free RTOS
>>>>>> Huntsville AL 35805 Support Available             (256)
>>>>>> 722-9985
>>>> _______________________________________________ rtems-users
>>> -- -------------------------------------------- Embedded Brains
>>> GmbH Thomas Doerfler           Obere Lagerstr. 30 D-82178
>>> Puchheim          Germany email:
>>> Thomas.Doerfler at embedded-brains.de Phone: +49-89-18908079-2 Fax:
>>> +49-89-18908079-9
>> _______________________________________________ rtems-users mailing
> Embedded Brains GmbH
> D-82178 Puchheim          Germany
> email: Thomas.Doerfler at embedded-brains.de
> Fax:   +49-89-18908079-9
