Stale cached data in bdbuf creates problems
Sebastian Huber
Wed May 2 12:31:26 UTC 2012
Hi,
attached is a small example that demonstrates the disk usage with two RAM
disks. It shows also that the principal mechanics work in RTEMS 4.10.
On 05/02/2012 12:27 PM, ali nasir wrote:
> Hi,
> After running the below unmount sequence, i put a break point at the said place.
> Then when a new device is inserted, the system tries to read the MBR. When the control comes at the break point, the bd is in the state RTEMS_BDBUF_STATE_CACHED.
Ok, there must be an error here. The state should be RTEMS_BDBUF_STATE_EMPTY.
Maybe it helps to enable the bdbuf tracing (in bdbuf.c):
#define RTEMS_BDBUF_TRACE 1
bool rtems_bdbuf_tracer = true;
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
Type: text/x-csrc
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20120502/b678a3cd/attachment.bin>
