Supported ARM BSPs
Fri May 4 02:22:39 UTC 2012
The correct name right now is arm-rtemseabi4.11
I expect the EABI toolchain will be re-named arm-rtems4.11 to replace
the current arm-rtems4.11 when it goes EOL. There was a bit of
confusion over the transition of these tools so keep an eye out for an
announcement and for now use arm-rtemseabi4.11
-Gedare
On Thu, May 3, 2012 at 5:11 PM, Steven Grunza <sgrunza at ctdi.com> wrote:
> What's the name of the correct toolchain, arm-rtemseabi4.11 or arm-rtems4.11?
> Steven Grunza
> Products Engineer
> CTDI | Products Division
> 1373 Enterprise Dr.
> West Chester, PA 19380
> phone: 610-793-8527
> e-mail: sgrunza at ctdi.com
> -----Original Message-----
> From: gedare at gwmail.gwu.edu [mailto:gedare at gwmail.gwu.edu] On Behalf Of Gedare Bloom
> Sent: Thursday, May 03, 2012 2:54 PM
> To: Steven Grunza
> Cc: rtems-users at rtems.org
> Subject: Re: Supported ARM BSPs
> On Thu, May 3, 2012 at 2:40 PM, Steven Grunza <sgrunza at ctdi.com> wrote:
>>>On 03/05/12 10:36, Fered wrote:
>>>> Is BSP for lm3s69xx works only on Qemu?
>>>Yes, this BSP works only on Qemu.  The low-level initialization for
>> clocks, pins, memory, etc. is missing.
>> If someone indicates what --enable-rtemsbsp="" invocation is necessary
>> to build the lm3s69xx BSP I'll try to see if I can come up with
>> something for a real-world lm3s8962 Eval board I have.  I don't have
>> an lm3s69xx eval board but I suspect the lm3s8962 is close enough to
>> the lm3s69xx that it will provide the information necessary.
>> Also a few notes on how to get a working copy of RTEMS new enough to
>> contain lm3s69xx but old enough to not fail to build would be helpful.
>> The clone I got from git and configured with the following didn't build:
>> ../rtems/configure --prefix=/opt/rtems-4.10.2 --target=arm-rtems4.10
>> --enable-networking --enable-cxx --enable-posix --enable-multilib
>> --enable-maintainer-mode --enable-rtemsbsp="edb7312 arm7tdmi
>> armcortexa9
>> stm32f4 nds"
> Yes you need the Git head for the new BSPs. Try to configure with
> rtems-4.11 target/prefix instead so you pull in the 4.11 toolchain.
> Ideally no version of RTEMS Git head should fail to build with the correct toolchain. Ideally. :)
> -Gedare
>> It failed in the testsuites for the stm32f4 BSP which is of course,
>> one of the ones in which I am interested...
>> gmake[6]: Entering directory
>> `/home/grunzasr/rtems/git/b-arm-rtems/arm-rtems4.10/c/stm32f4/testsuit
>> es
>> /samples/hello'
>> arm-rtems4.10-gcc -B../../../../../lib/ -B../../../../../stm32f4/lib/
>> -specs bsp_specs -qrtems -march=armv7-m -mthumb -O2 -g -Wall
>> -Wmissing-prototypes -Wimplicit-function-declaration
>> -Wstrict-prototypes -Wnested-externs    -march=armv7-m -mthumb   -o
>> hello.exe init.o
>> ../../../../../stm32f4/lib/librtemsbsp.a(libbsp_a-armv7m-irq-dispatch.
>> o)
>> : In function `_ARMV7M_NVIC_Interrupt_dispatch':
>> /home/grunzasr/rtems/git/b-arm-rtems/arm-rtems4.10/c/stm32f4/lib/libbs
>> p/
>> arm/stm32f4/../../../../../../../../rtems/c/src/lib/libbsp/arm/stm32f4/.
>> ./shared/armv7m/irq/armv7m-irq-dispatch.c:27: undefined reference to
>> `_ARMV7M_Interrupt_service_enter'
>> p/
>> ./shared/armv7m/irq/armv7m-irq-dispatch.c:29: undefined reference to
>> `_ARMV7M_Interrupt_service_leave'
>> collect2: ld returned 1 exit status
>> gmake[6]: *** [hello.exe] Error 1
>> gmake[6]: Leaving directory
>> es
>> /samples/hello'
>> gmake[5]: *** [all-recursive] Error 1
>> gmake[5]: Leaving directory
>> es
>> /samples'
>> gmake[4]: *** [all] Error 2
>> gmake[4]: Leaving directory
>> es
>> /samples'
>> gmake[3]: *** [all-recursive] Error 1
>> gmake[3]: Leaving directory
>> es
>> gmake[2]: *** [all-recursive] Error 1
>> gmake[2]: Leaving directory
>> `/home/grunzasr/rtems/git/b-arm-rtems/arm-rtems4.10/c/stm32f4'
>> gmake[1]: *** [all-recursive] Error 1
>> gmake[1]: Leaving directory
>> `/home/grunzasr/rtems/git/b-arm-rtems/arm-rtems4.10/c'
>> make: *** [all-recursive] Error 1
>> rtems-users mailing list
>> http://www.rtems.org/mailman/listinfo/rtems-users
