Running lm3s6965 BSP on Qemu
Hesham Moustafa
heshamelmatary at gmail.com
Sat May 5 18:00:15 UTC 2012
There is no hello.bin , only .ralf , .num , .ext and i have tried them all
and i get the same result .
I'am using qemu i built , and using qemu-system-arm and of course it's in
my PATH
On Sat, May 5, 2012 at 7:55 PM, Joel Sherrill <joel.sherrill at oarcorp.com>wrote:
> Are you using the qemu you built? Did you update your PATH
> type qemu-system-arm
> And check
> Hesham Moustafa <heshamelmatary at gmail.com> wrote:
> >I git pull the specified patches
> >and then run
> >make c/lm3s6965/testsuites/samples/hello
> >qemu-system-arm -S -s -net none -nographic -M lm3s6965evb -kernel
> hello.exe
> >but i got that only and nothing happens
> >"Warning: nic stellaris_enet.0 has no peer "
> >On Sat, May 5, 2012 at 6:20 PM, Hesham Moustafa <heshamelmatary at gmail.com
> <mailto:heshamelmatary at gmail.com>> wrote:
> >I have tried the patches in the qemu source and the script but it works
> for normal qemu command line , not qemu-system-arm , when i edited it to be
> qemu-system-arm it output an error " kernel image must be specified " , So
> i get qemu-system-arm to work manually through the rtems-boot.img and wrote
> some options like set root (hd0,0)
> >multiboot ....... and specified the hello.exe but i got an error "
> address 0x0 is out of range "
> >On Sat, May 5, 2012 at 5:52 PM, Joel Sherrill <joel.sherrill at oarcorp.com
> <mailto:joel.sherrill at oarcorp.com>> wrote:
> >There are patches for qemu in the bsp source directory. I am not sure but
> seriously doubt if those are in any pre-packaged qemu binary. I am not even
> sure if they have been merged by qemu. Sebastian should know that.
> >Grab the qemu source, check if the patches apply and build you own.
> >How are invoking qemu?
> >Hesham Moustafa <heshamelmatary at gmail.com<mailto:heshamelmatary at gmail.com>>
> wrote:
> >>I am trying to get lm3s6965 BSP to work on Qemu .
> >>I followed some instruction in a Wiki page but in vain .
> >>It would be great if some one give me DEFINITE INSTRUCTIONS to get it
> >>work . I have fedora 16 with latest qemu-system-arm command line .
> >>thanks,
> >>Hesham
URL: <http://lists.rtems.org/pipermail/users/attachments/20120505/eec4464d/attachment.html>
