Running lm3s6965 BSP on Qemu
Sat May 5 19:36:54 UTC 2012
On 05/05/12 19:25, Hesham Moustafa wrote:
> qemu-system-arm -S -s -net none -nographic -M lm3s6965evb -kernel hello.exe
> but i got that only and nothing happens
> "Warning: nic stellaris_enet.0 has no peer"
Quite frankly, try to understand the Qemu options you are using:
qemu-system-arm --help | grep -- '-[Ss]\>'
-S              freeze CPU at startup (use 'c' to start execution)
-s              shorthand for -gdb tcp::1234
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
