rtems-users Digest, Vol 68, Issue 12
Hesham Moustafa
heshamelmatary at gmail.com
Sat May 5 20:02:18 UTC 2012
I just followed the instruction you gave me here
> >>http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/lm3s69xx/README
> BTW , i have run it using this command
> qemu-system-arm -net none -nographic -M lm3s6965evb -kernel hello.exe
> i got this
> Warning: nic stellaris_enet.0 has no peer
> qemu: hardware error: gic_dist_writeb: Bad offset d1f
> CPU #0:
> R00=0000000b R01=000000ff R02=0000618d R03=e000ed07
> R04=0000000b R05=0000618d R06=00000000 R07=00000000
> R08=00000000 R09=00000000 R10=00000000 R11=00000000
> R12=00000001 R13=200010f0 R14=0000752b R15=0000753c
> PSR=20000173 --C- T svc32
> Aborted (core dumped)
> i tried
> qemu-system-arm -net none -nographic -M lm3s6965evb -kernel hello.num
> and i got this
> qemu: fatal: Trying to execute code outside RAM or ROM at 0x20202020
> R00=00000000 R01=00000000 R02=00000000 R03=00000000
> R04=00000000 R05=00000000 R06=00000000 R07=00000000
> R12=00000000 R13=20202020 R14=00000000 R15=20202020
> PSR=40000153 -Z-- A svc32
URL: <http://lists.rtems.org/pipermail/users/attachments/20120505/eca3c024/attachment.html>
