rtems-users Digest, Vol 68, Issue 12
Sat May 5 20:25:14 UTC 2012
On 05/05/12 22:02, Hesham Moustafa wrote:
> I just followed the instruction you gave me here
>>>> >  >>http://git.rtems.org/rtems/tree/c/src/lib/libbsp/arm/lm3s69xx/README
>> >  BTW , i have run it using this command
>> >  qemu-system-arm -net none -nographic -M lm3s6965evb -kernel hello.exe
>> >  i got this
>> >  Warning: nic stellaris_enet.0 has no peer
>> >  qemu: hardware error: gic_dist_writeb: Bad offset d1f
Make sure you build Qemu following the instructions in the README and
make sure that you use the right Qemu on your system.
>> >  qemu-system-arm -net none -nographic -M lm3s6965evb -kernel hello.num
This makes no sense.  Do you know what this *.num file is?
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
