MCF5485EVB Board Console problems
Chris Xenophontos cxenophontos at hammers.com
Mon May 7 13:15:50 UTC 2012
I see - We'll re-do it and post back,
thanks!
Chris Xenophontos
On Mon, May 7, 2012 at 9:07 AM, Sebastian Huber
> On 05/07/2012 03:04 PM, Chris Xenophontos wrote:
>> We have no output on console terminal when starting application.  When
>> disabling terminal driver, and using printk, we have  output on
>> console, and our application runs.
>> I did not run ./bootstrap after making the changes - is that what is
>> needed?
> Yes, if configure.ac and Makefile.am files are changed then the bootstrap is
> needed.  Sometimes a --enable-maintainer-mode helps to avoid this bootstrap
> after updates.
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone   : +49 89 18 90 80 79-6
> Fax     : +49 89 18 90 80 79-9
> E-Mail  : sebastian.huber at embedded-brains.de
> PGP     : Public key available on request.
