MCF5485EVB Board Console problems
Chris Xenophontos cxenophontos at hammers.com
Tue May 8 13:17:50 UTC 2012
Success!
After running bootstrap, configure/make, application now initializes
with the console, and we can use printf among other things.
Thanks so much!
Chris Xenophontos
On Mon, May 7, 2012 at 9:15 AM, Chris Xenophontos
<cxenophontos at hammers.com> wrote:
> I see - We'll re-do it and post back,
> thanks!
> Chris Xenophontos
> On Mon, May 7, 2012 at 9:07 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 05/07/2012 03:04 PM, Chris Xenophontos wrote:
>>> We have no output on console terminal when starting application.  When
>>> disabling terminal driver, and using printk, we have  output on
>>> console, and our application runs.
>>> I did not run ./bootstrap after making the changes - is that what is
>>> needed?
>> Yes, if configure.ac and Makefile.am files are changed then the bootstrap is
>> needed.  Sometimes a --enable-maintainer-mode helps to avoid this bootstrap
>> after updates.
>> Sebastian Huber, embedded brains GmbH
>> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>> Phone   : +49 89 18 90 80 79-6
>> Fax     : +49 89 18 90 80 79-9
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
