question about rtems compiler
Luca Cinquepalmi
cinquepalmi at planetek.it
Wed May 9 12:10:46 UTC 2012
I have no error... I'd just like to know the difference bewtween a
simple C source code (with main function)
and rtems structured one... thanks.
Il 09/05/2012 13.41, Wendell Silva ha scritto:
> Luca,
> What kind of erros?
> Can you post the error message, please?
> I suppose you are not using the -B command line option properly, which
> yelds linker error.
> --Wendell.
> 2012/5/9 Luca Cinquepalmi <cinquepalmi at planetek.it
> <mailto:cinquepalmi at planetek.it>>
> Can anybody explain me why rtems gcc compiler doesn't compile a
> simple C source
> code with main? I need to adopt a rtems structured code to compile
> it... How does compiler
> understand where to start? Is the main funcion included in some
> rtems macros?
> thanks a lot
> Luca
> rtems-users mailing list
> rtems-users at rtems.org <mailto:rtems-users at rtems.org>
URL: <http://lists.rtems.org/pipermail/users/attachments/20120509/6b87c674/attachment.html>
