Coldfire (MCF5235) Interrupt Problem
Joel Sherrill
joel.sherrill at OARcorp.com
Tue May 15 15:29:21 UTC 2012
On 05/15/2012 10:09 AM, Ivica Eftimovski wrote:
> Well it was self-inflicted wound. I found that my Data Direction
> Register setting was incorrect (MCF5235_EPORT_EPDDR). It was supposed
> to be NOT(), and it is supposed to be 8bits, not 16 bits as the User
> Manual has it. RTEMS has it correctly set to 8bits.
If you have any macros, etc which aid in programming the
DDR, please feel free to submit them. We welcome anything
that makes the next person's experience a little better. :)
> Thank you all for the time and help.
Thank you for following up on the list to report what the issue
turned out to be. Google remembers all and when people see
"problem" in a subject, it is nice from a project perspective to
see the resolution. Whether it is RTEMS' problem or a user
issue.
--joel
> Regards,
> Ivica
> *From:*rtems-users-bounces at rtems.org
> [mailto:rtems-users-bounces at rtems.org] *On Behalf Of *Ivica Eftimovski
> *Sent:* Friday, May 11, 2012 11:56 AM
> *To:* rtems-users at rtems.org
> *Subject:* Coldfire (MCF5235) Interrupt Problem
> Hi all,
> I am just starting with RTEMS and I am trying to interface the MCF5235
> BCC board to our existing hardware. I am trying to set it to use
> *IRQ4, which should have fixed level/priority.
> When I execute the code noted below, the interrupts are disabled
> properly, the vector seems set and interrupts are re-enabled. But
> anytime I ground*IRQ4 (default high) line while my example program is
> running, I do not vector to the ISR.
> I fashioned my code using the clock/network/console code as guide, and
> those work great.
> Can anyone please give me a hint of what am I doing wrong?
> ------------------------------------- CODE
> #define TPU_INT_VECTOR (64+4)
> #define TPU_IRQ_LEVEL 4
> #define TPU_IRQ_PRIORITY 4
> void InitTPUInterrupt(void);
> static rtems_isr TPUInterruptHandler(rtems_vector_number vector);
> #define TPUInterruptSetPriority() \
> do { \
> MCF5235_INTC0_ICR4 = \
> MCF5235_INTC_ICR_IL(TPU_IRQ_LEVEL) | \
> MCF5235_INTC_ICR_IP(TPU_IRQ_PRIORITY); \
> } while(0)
> #define TPUInterruptSetHandler(_level,_vector,_old_handler) \
> do { \
> rtems_interrupt_disable(_level); \
> MCF5235_INTC0_IMRL &= ~(MCF5235_INTC0_IMRL_INT4 | \
> MCF5235_INTC0_IMRL_MASKALL); \
> handle_status = rtems_interrupt_catch(TPUInterruptHandler, \
> TPU_INT_VECTOR, &old_handler); \
> rtems_interrupt_enable(level); \
> } while(0)
> void InitTPUInterrupt(void) {
> rtems_interrupt_level level;
> rtems_isr_entry old_handler;
> uint16 status;
> TPUInterruptSetPriority();
> TPUInterruptSetHandler(level, TPU_INT_VECTOR, old_handler);
> asm ("move.w %%sr ,%0;" : "=r"(status));
> static rtems_isr
> uint volatile chan = vector - TPU_INT_VECTOR;
> printf("\nGot interrupt number: %i", chan);
> rtems_interrupt_clear(MCF5235_INTC0_ICR4);
> rtems_task Init(
> rtems_task_argument ignored
> InitTPUInterrupt();
Joel Sherrill, Ph.D. Director of Research& Development
URL: <http://lists.rtems.org/pipermail/users/attachments/20120515/c2b440c5/attachment.html>
