RES: RES: Different tick interval with the same application between RTEMS 4.10.0 and 4.10.2?
Joel Sherrill
joel.sherrill at OARcorp.com
Mon May 21 19:36:21 UTC 2012
On 05/21/2012 01:33 PM, Fabrício de Novaes Kucinskis wrote:
> Yes Joel, GDB changed to 7.2. The extension of SIS internal cycle
> counter was the main reason for our upgrade.
> The RTC counter is programmed with the same value for both BSP’s. I’m
> starting to think that this is related to the GDB update.
> I’m just curious about why would you expect that the change of the
> counter’s length would make SIS faster…?
Random hunches.
+ The native GCC used to compile the binary was newer and it
got better at the inner loop between the two points.
+ The change to the 64-bit cycle counter also simplified the
inner loop of the simulator in some way that either by itself
made it faster, or let the same gcc do a better job.
The gdb version is independent of the RTEMS version. You
can always compare the execution times of the same binaries
on them.
--joel
> *De:*Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> *Enviada em:* segunda-feira, 21 de maio de 2012 15:14
> *Para:* Fabrício de Novaes Kucinskis
> *Cc:* 'RTEMS Users'
> *Assunto:* Re: RES: Different tick interval with the same application
> On 05/21/2012 12:55 PM, Fabrício de Novaes Kucinskis wrote:
> Hi Joel, and thanks for your answer,
> The “one second” reference I used is real time (ERC32 BSP). When
> simulating (SIS BSP), things run a little faster. But not as fast as
> what we are seeing now.
> We checked (both a dump of the .exe and with a breakpoint at
> Clock_isr), and the fast idle mode is not #included in the application
> compiled for SIS.
> Could this be a side-effect of the nanoseconds change? I don’t think
> so, as we’re not enabling the extension. But don’t know where else to
> look for.
> I don't think so either. The timer should be programmed with the same
> value
> on both sis and real hardware.
> That's the only thing to check.
> By any chance did the version of gdb change? Or did the binary change?
> I am thinking that an sis with 64-bit internal cycle counter might be
> faster
> than the version with 32-bit internal cycle counter.
> We also compiled the same application with both versions of RTEMS and
> run in an ERC32 board. Both run at the same 1-second interval. As this
> is our main target, the issue with the simulator shouldn’t bother us
> too much. But I think it’s always important to report to the list when
> something doesn’t work as expected – maybe the observed behavior point
> to something to be improved or fixed.
> Thanks again,
> Fabrício.
> *Enviada em:* segunda-feira, 21 de maio de 2012 11:26
> *Cc:* 'RTEMS Users'
> *Assunto:* Re: Different tick interval with the same application
> On 05/21/2012 08:49 AM, Fabrício de Novaes Kucinskis wrote:
> Hi all,
> We've just upgraded our development environment from RTEMS 4.10.0 to
> RTEMS 4.10.2. As always, an interesting issue has raised! ;-)
> We use the ERC32 and SIS BSPs. After the upgrade, a simple test
> application that prints a clock once per second started to print the
> clock values almost two times faster on SIS. The application gets the
> number of ticks per second and uses it in the rtems_task_wake_after
> directive.
> When on any simulator, there is always the possibility that somehow
> the fast idle mode
> in the clock driver got turned on.
> To determine if the issue was on SIS or RTEMS, we run in the 4.10.2
> environment the previous version of the test, compiled with RTEMS
> 4.10.0, and the task runs once per second. Also, the number of ticks
> per second reported in both versions is the same.
> Is this once per second in simulated or real time?
> Set a break point at Clock_isr and see if it is doing the fast idle mode.
> Looking at the release notes, we've found a number of changes/fixes
> related with ticks and time since 4.10.0. But it seems that none of
> them is related to what I report here.
> I looked at the diff files and the only changes are fixing bugs
> related to nanoseconds since last tick when you ask on the
> edge of a tick interrupt occurring.
> Is this something to be expected when upgrading? Am I missing some
> change in the configuration?
> Thanks in advance and best regards,
> Fabrício de Novaes Kucinskis.
> Joel Sherrill, Ph.D. Director of Research& Development
> joel.sherrill at OARcorp.com <mailto:joel.sherrill at OARcorp.com> On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/users/attachments/20120521/5291b89f/attachment.html>
