cross-compiling LIBGMP for arm-rtemseabi4.11 toolchain
Jiri Freyvald
jiri.freyvald at gmail.com
Wed May 23 15:48:51 UTC 2012
Hello,
I am just at the beginning to discover RTEMS. I am interested mainly in
the existing port for STM32F4xx board as it is at the moment one of the
most affordable board available.
I installed VirtualBox image RTEMS 4.11 CentOS 6.2 and tried to follow
all the steps described
on wiki:
http://www.rtems.com/wiki/index.php/Virtual_Machines_for_RTEMS_Development
but as I need to create cross-toolchain for arm-rtemseabi4.11, I have to
build GMP and MPC for the same cross platform,
so I modified configure for GMP to:
./configure --build=arm-rtemseabi4.11
and I got error:
checking size of mp_limb_t... 8
configure: error: Oops, mp_limb_t is 64 bits, but the assembler code
in this configuration expects 32 bits.
It is probably GMP issue, or some parameter is missing,
because when I tried the same with ARM toolchain (which I have been
using for some time recently):
./configure --build=arm-none-eabi
I got the same error.
Have anyone had the same problem? Or do you have any clue what have I
done wrong?
Thank you in advance for your help,
Jiri
