cross-compiling LIBGMP for arm-rtemseabi4.11 toolchain
Jiri Freyvald jiri.freyvald at gmail.com
Wed May 23 16:51:18 UTC 2012
On 05/23/2012 05:31 PM, Ralf Corsepius wrote:
> On 05/23/2012 06:07 PM, Gedare Bloom wrote:
>> On Wed, May 23, 2012 at 11:48 AM, Jiri
>> Freyvald<jiri.freyvald at gmail.com>  wrote:
>>> ./configure --build=arm-rtemseabi4.11
>> Maybe this should be --target=arm-rtemseabi4.11 I'm not sure if it
>> would make a difference.
I tried put --target too, but it tells me:
configure: error: --target is not appropriate for GMP
Use --build=CPU-VENDOR-OS if you need to specify your CPU and/or system
explicitly.
Use --host if cross-compiling
and I tried --host=arm-rtemseabi4.11 and it gave me the same error as in
case --build
> rtems-users mailing list
> rtems-users at rtems.org
