MCF5485EVB Board Console problems
Thomas Doerfler
Thomas.Doerfler at embedded-brains.de
Tue May 1 15:37:31 UTC 2012
Chris,
can you successfully execute one of the "sample" applications built for
this board, like "ticker.exe" ?
These applications should be present in your "install" tree since you
haven't disabled them explicitly in your configure line.
Are you working with a real "mcf5484FireEngine" board or is it different
in some areas?
Which boot monitor do you use?
wkr,
Thomas.
Am 01.05.2012 17:19, schrieb Chris Xenophontos:
> The problem occurs regardless if CONFIGURE_TERMIOS_DISABLED is #defined or not.
> We've repeatedly tried it both ways.
> On Tue, May 1, 2012 at 10:48 AM, Chris Xenophontos
>> On Tue, May 1, 2012 at 10:43 AM, Joel Sherrill
>> <joel.sherrill at oarcorp.com> wrote:
>>> You can't disable TERMIOS and have a working console driver.
>>> On 05/01/2012 09:41 AM, Chris Xenophontos wrote:
>>>> Hello,
>>>> In continuing to port a previous application to an MCF5485EVB board
>>>> with RTEMS 4.10.2,
>>>> We're having problems initializing the console. Currently, we
>>>> successfully configured as follows:
>>>> ./rtems-4.10.2/configure --target=m68k-rtems4.10
>>>> --enable-rtemsbsp=m5484FireEngine --prefix=/opt/rtems-4.10
>>>> gmake RTEMS_BSP="m5484FireEngine" install
>>>> The problem is that when CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER is
>>>> #defined,
>>>> Either the application is not initializing, or no output is sent
>>>> through serial port. Only way to get any
>>>> messages to console window is to use printk.
>>>> The snipped below had previously worked as shown, on MCF5235 board
>>>> with RTEMS 4.9 - no issues with console.
>>>> Is additional configuration required for m5484FireEngine BSP?
>>>> thanks
>>>> Chris Xenophontos
>>>> include<stdio.h>
>>>> #include<stdlib.h>
>>>> #include<rtems.h>
>>>> #include<bsp.h>
>>>> #include<unistd.h>
>>>> #include<rtems/rtems_bsdnet.h>
>>>> #include "networkconfig.h"
>>>> #include "tids.h"
>>>> #include "pids.h"
>>>> #include "ostasks.h"
>>>> #include "debug.h"
>>>> rtems_task Init( rtems_task_argument ignored );
>>>> extern int myAppMain( void );
>>>> // !! forced to use prink - #defining
>>>> CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER won't initialize - see
>>>> below
>>>> printk( "\n\n\nMMS Trainer Initializing...\n" );
>>>> printk( "\n*** RTEMS Info ***" );
>>>> printk( "\n" );
>>>> printk( "\nsizeof( Objects_Control *): 0x%08X", (
>>>> unsigned int )sizeof( Objects_Control *));
>>>> printk( "\nsizeof( rtems_name *): 0x%08X", (
>>>> unsigned int )sizeof( rtems_name *));
>>>> printk( "\nsizeof( rtems_name ): 0x%08X", (
>>>> unsigned int )sizeof( rtems_name ));
>>>> printk( "\n" );
>>>> printk( "\nsizeof(Thread_Control): 0x%08X", (
>>>> unsigned int )sizeof(Thread_Control ));
>>>> printk( "\nCONTEXT_FP_SIZE: 0x%08X", (
>>>> unsigned int )CONTEXT_FP_SIZE );
>>>> printk( "\nSTACK_MINIMUM_SIZE: 0x%08X",
>>>> STACK_MINIMUM_SIZE );
>>>> printk( "\nsizeof( RTEMS_API_Control ): 0x%08X", (
>>>> unsigned int )sizeof( RTEMS_API_Control ));
>>>> printk( "\n" );
>>>> rtems_bsdnet_initialize_network();
>>>> rtems_bsdnet_show_inet_routes ();
>>>> rtems_bsdnet_show_mbuf_stats ();
>>>> rtems_bsdnet_show_if_stats ();
>>>> rtems_bsdnet_show_ip_stats ();
>>>> rtems_bsdnet_show_icmp_stats ();
>>>> rtems_bsdnet_show_udp_stats ();
>>>> rtems_bsdnet_show_tcp_stats ();
>>>> #ifdef STACK_DEBUG
>>>> Stack_check_Initialize();
>>>> #endif
>>>> printk( "\nEntering xmain....\n" );
>>>> myAppMain(); /* application, startup, etc */
>>>> exit ( 0 );
>>>> #define TASK_INTLEVEL 0
>>>> #define CONFIGURE_INIT
>>>> #define CONFIGURE_INIT_TASK_ATTRIBUTES ( RTEMS_FLOATING_POINT |
>>>> RTEMS_PREEMPT | RTEMS_NO_TIMESLICE | RTEMS_ASR |
>>>> RTEMS_INTERRUPT_LEVEL(TASK_INTLEVEL))
>>>> #define CONFIGURE_MAXIMUM_TASKS 20
>>>> #define CONFIGURE_MAXIMUM_TIMERS 3
>>>> #define CONFIGURE_MAXIMUM_SEMAPHORES 20
>>>> #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 24
>>>> #define CONFIGURE_INIT_TASK_STACK_SIZE (10*1024)
>>>> #define CONFIGURE_INIT_TASK_PRIORITY 120
>>>> #define CONFIGURE_INIT_TASK_INITIAL_MODES (RTEMS_PREEMPT | \
>>>> RTEMS_NO_TIMESLICE | \
>>>> RTEMS_NO_ASR | \
>>>> RTEMS_INTERRUPT_LEVEL(0))
>>>> //#define CONFIGURE_MAXIMUM_DEVICES 4
>>>> #define CONFIGURE_MAXIMUM_DRIVERS 3
>>>> #define ADA_TASKS 0
>>>> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>>>> //#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER !!!! no
>>>> initialization/console output when defined !!!
>>>> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>>>> // #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
>>>> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 4 /* 30 */
>>>> #define CONFIGURE_MICROSECONDS_PER_TICK 10000
>>>> #define CONFIGURE_TERMIOS_DISABLED
>>>> #ifdef STACK_DEBUG
>>>> #define STACK_CHECKER_ON
>>>> #endif
>>>> #include<rtems/confdefs.h>
>>>> #define NETWORK_TASK_PRIORITY 80
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-users
>>> Joel Sherrill, Ph.D. Director of Research& Development
>>> joel.sherrill at OARcorp.com On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS Huntsville AL 35805
>>> Support Available (256) 722-9985
Embedded Brains GmbH
Thomas Doerfler Obere Lagerstr. 30
D-82178 Puchheim Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax: +49-89-18908079-9
