Supported ARM BSPs
Steven Grunza sgrunza at ctdi.com
Thu May 3 18:40:04 UTC 2012
>On 03/05/12 10:36, Fered wrote:
>> Is BSP for lm3s69xx works only on Qemu?
>Yes, this BSP works only on Qemu.  The low-level initialization for
clocks, pins, memory, etc. is missing.
If someone indicates what --enable-rtemsbsp="" invocation is necessary
to build the lm3s69xx BSP I'll try to see if I can come up with
something for a real-world lm3s8962 Eval board I have.  I don't have an
lm3s69xx eval board but I suspect the lm3s8962 is close enough to the
lm3s69xx that it will provide the information necessary.
Also a few notes on how to get a working copy of RTEMS new enough to
contain lm3s69xx but old enough to not fail to build would be helpful.
The clone I got from git and configured with the following didn't build:
../rtems/configure --prefix=/opt/rtems-4.10.2 --target=arm-rtems4.10
--enable-networking --enable-cxx --enable-posix --enable-multilib
--enable-maintainer-mode --enable-rtemsbsp="edb7312 arm7tdmi armcortexa9
stm32f4 nds"
It failed in the testsuites for the stm32f4 BSP which is of course, one
of the ones in which I am interested...
gmake[6]: Entering directory
`/home/grunzasr/rtems/git/b-arm-rtems/arm-rtems4.10/c/stm32f4/testsuites
/samples/hello'
arm-rtems4.10-gcc -B../../../../../lib/ -B../../../../../stm32f4/lib/
-specs bsp_specs -qrtems -march=armv7-m -mthumb -O2 -g -Wall
-Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
-Wnested-externs    -march=armv7-m -mthumb   -o hello.exe init.o
../../../../../stm32f4/lib/librtemsbsp.a(libbsp_a-armv7m-irq-dispatch.o)
: In function `_ARMV7M_NVIC_Interrupt_dispatch':
/home/grunzasr/rtems/git/b-arm-rtems/arm-rtems4.10/c/stm32f4/lib/libbsp/
arm/stm32f4/../../../../../../../../rtems/c/src/lib/libbsp/arm/stm32f4/.
./shared/armv7m/irq/armv7m-irq-dispatch.c:27: undefined reference to
`_ARMV7M_Interrupt_service_enter'
./shared/armv7m/irq/armv7m-irq-dispatch.c:29: undefined reference to
`_ARMV7M_Interrupt_service_leave'
collect2: ld returned 1 exit status
gmake[6]: *** [hello.exe] Error 1
gmake[6]: Leaving directory
/samples/hello'
gmake[5]: *** [all-recursive] Error 1
gmake[5]: Leaving directory
/samples'
gmake[4]: *** [all] Error 2
gmake[4]: Leaving directory
/samples'
gmake[3]: *** [all-recursive] Error 1
gmake[3]: Leaving directory
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory
`/home/grunzasr/rtems/git/b-arm-rtems/arm-rtems4.10/c/stm32f4'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory
`/home/grunzasr/rtems/git/b-arm-rtems/arm-rtems4.10/c'
make: *** [all-recursive] Error 1
