Running lm3s6965 BSP on Qemu
Sat May 5 17:55:11 UTC 2012
Are you using the qemu you built? Did you update your PATH
type qemu-system-arm
And check
Hesham Moustafa <heshamelmatary at gmail.com> wrote:
>I git pull the specified patches
>and then run
>make c/lm3s6965/testsuites/samples/hello
>qemu-system-arm -S -s -net none -nographic -M lm3s6965evb -kernel hello.exe
>but i got that only and nothing happens
>"Warning: nic stellaris_enet.0 has no peer "
>On Sat, May 5, 2012 at 6:20 PM, Hesham Moustafa <heshamelmatary at gmail.com<mailto:heshamelmatary at gmail.com>> wrote:
>I have tried the patches in the qemu source and the script but it works for normal qemu command line , not qemu-system-arm , when i edited it to be qemu-system-arm it output an error " kernel image must be specified " , So i get qemu-system-arm to work manually through the rtems-boot.img and wrote some options like set root (hd0,0)
>multiboot ....... and specified the hello.exe but i got an error " address 0x0 is out of range "
>On Sat, May 5, 2012 at 5:52 PM, Joel Sherrill <joel.sherrill at oarcorp.com<mailto:joel.sherrill at oarcorp.com>> wrote:
>There are patches for qemu in the bsp source directory. I am not sure but seriously doubt if those are in any pre-packaged qemu binary. I am not even sure if they have been merged by qemu. Sebastian should know that.
>Grab the qemu source, check if the patches apply and build you own.
>How are invoking qemu?
>>I am trying to get lm3s6965 BSP to work on Qemu .
>>I followed some instruction in a Wiki page but in vain .
>>It would be great if some one give me DEFINITE INSTRUCTIONS to get it
>>work . I have fedora 16 with latest qemu-system-arm command line .
>>thanks,
>>Hesham
