question about rtems compiler
Wendell Silva silvawp at gmail.com
Wed May 9 11:41:21 UTC 2012
Luca,
What kind of erros?
Can you post the error message, please?
I suppose you are not using the -B command line option properly, which
yelds linker error.
--Wendell.
2012/5/9 Luca Cinquepalmi <cinquepalmi at planetek.it>
> Can anybody explain me why rtems gcc compiler doesn't compile a simple C
> source
> code with main? I need to adopt a rtems structured code to compile it...
> How does compiler
> understand where to start? Is the main funcion included in some rtems
> macros?
> thanks a lot
>    Luca
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20120509/71628098/attachment-0001.html>
