cross-compiling LIBGMP for arm-rtemseabi4.11 toolchain
Gedare Bloom
gedare at rtems.org
Wed May 23 17:14:28 UTC 2012
On Wed, May 23, 2012 at 12:51 PM, Jiri Freyvald <jiri.freyvald at gmail.com> wrote:
> On 05/23/2012 05:31 PM, Ralf Corsepius wrote:
>> On 05/23/2012 06:07 PM, Gedare Bloom wrote:
>>> On Wed, May 23, 2012 at 11:48 AM, Jiri Freyvald<jiri.freyvald at gmail.com>
>>> wrote:
>>>> ./configure --build=arm-rtemseabi4.11
>>> Maybe this should be --target=arm-rtemseabi4.11 I'm not sure if it
>>> would make a difference.
> I tried put --target too, but it tells me:
> configure: error: --target is not appropriate for GMP
> Use --build=CPU-VENDOR-OS if you need to specify your CPU and/or system
> explicitly.
> Use --host if cross-compiling
> and I tried --host=arm-rtemseabi4.11 and it gave me the same error as in
> case --build
host would be your desktop, e.g. x86_64-linux or something. I guess
try to install the packages from EPEL as Ralf suggested, and/or link
the gmp and mpc library sources in your gcc source tree directly and
just build gcc.
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-users
