cross-compiling LIBGMP for arm-rtemseabi4.11 toolchain
Jiri Freyvald
jiri.freyvald at gmail.com
Thu May 31 17:54:20 UTC 2012
Well,
I forgot to mentioned that I finally installed rtems toolchain on my
archlinux distro (which doesn't use rpm).
So i extracted rtems packages using rpmextract.
And because I already have mpfr and gmp in my distro, instead of
extracting mpfr and gmp rpms I created link to existing libmpfr and
libgmp (I have newer version of both libraries)
Seems to work - at least i was able to build examples_v2 and run them in
sparc simulator.
Jiri
On 05/31/12 17:33, Ralf Corsepius wrote:
> On 05/31/2012 05:17 PM, Jiri Freyvald wrote:
>> Hi,
>> finally I succeed with building cross toolchain for ARM.
>> soft-links /usr/lib/libmpfr.so.1 and /usr/lib/libgmp.so.3 to my version
>> of those libs
>> solved the problem.
> I fail to understand this.
> http://mirror.centos.org/centos/6/os/x86_64/Packages/mpfr-2.4.1-6.el6.x86_64.rpm
> and
> http://mirror.centos.org/centos/6/os/x86_64/Packages/gmp-4.3.1-7.el6.x86_64.rpm
> Are the packages the rpms use.
> (The corresponding *-devel packages are the packages the rpms are
> being build against)
>> Now I can install toolchain using rpm's from .../centos/6/x86_64/
>> or build cross toolchain from source code. Both works.
> Provided your yum configuration is set up correctly,
> yum install <...>
> is supposed to work and to pull the packages mentioned above
> automatically.
> Ralf
> rtems-users mailing list
> rtems-users at rtems.org
