File system and CompactFlash question on MCF5485EVB board
Tue Nov 13 15:59:36 UTC 2012
On 11/13/2012 04:31 PM, Chris Xenophontos wrote:
> ////////////////  from application initialization code  ////////////////////////
>      sc = rtems_bdpart_register_from_disk( "/dev/hda" );
>      rv = rtems_fsmount( fs_table, sizeof(fs_table)/sizeof(fs_table[0]), NULL);
> what are we doing wrong?
You should check the return status codes.
Does the rtems_bdpart_register_from_disk() create the "/dev/hda1" and
"/dev/hda2" device files?
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
