File system and CompactFlash question on MCF5485EVB board
Chris Xenophontos
cxenophontos at hammers.com
Tue Nov 13 17:26:34 UTC 2012
Return codes are zero for both rtems_bdpart_register_from_disk() and
rtems_fsmount(). Previously returned 27 when we had driver problems.
I know that /dev/hda1 is created.
thanks
cx
> On Tue, Nov 13, 2012 at 10:59 AM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 11/13/2012 04:31 PM, Chris Xenophontos wrote:
>>> //////////////// from application initialization code
>>> sc = rtems_bdpart_register_from_**disk( "/dev/hda" );
>>> rv = rtems_fsmount( fs_table, sizeof(fs_table)/sizeof(fs_**table[0]),
>>> NULL);
>>> what are we doing wrong?
>> You should check the return status codes.
>> Does the rtems_bdpart_register_from_**disk() create the "/dev/hda1" and
>> "/dev/hda2" device files?
>> Sebastian Huber, embedded brains GmbH
>> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>> Phone : +49 89 18 90 80 79-6
>> Fax : +49 89 18 90 80 79-9
>> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> ______________________________**_________________
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20121113/e5c0327f/attachment.html>
