File system and CompactFlash question on MCF5485EVB board
Chris Xenophontos
cxenophontos at hammers.com
Wed Nov 14 14:56:35 UTC 2012
I should also mention, when I dump C/H/S ( 0/0/1), the following data is
seen:
Bytes 0 thru 445: all zeros
Bytes 446 thru 512:
8001 0100 0BFE FFFF 3F00 0000 417A 7700 ( first partition only?)
0000 0000 0000 0000 0000 0000 0000 0000
0000 0000 0000 0000 0000 0000 0000 0000 55AA
As I mentioned earlier, this information is unobtainable (all zeros) when
the card is used in LBA mode.
thanks
Chris Xenophontos
On Wed, Nov 14, 2012 at 9:26 AM, Chris Xenophontos <cxenophontos at hammers.com
> wrote:
> Yes, /dev/hda2 also. Also the Compact Flash card is formatted as FAT32.
> Could this be the problem?
> On Wed, Nov 14, 2012 at 2:35 AM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 11/13/2012 06:10 PM, Chris Xenophontos wrote:
>>> Return codes are zero for both rtems_bdpart_register_from_**disk() and
>>> rtems_fsmount(). Previously, returned 27 when we had driver problems.
>>> I know that /dev/hda1 is created.
>> Yes, but what about "dev/hda2"? You mentioned this error:
>> fsmount: mounting of "/dev/hda2" to "/mnt/hda2" failed: No such file or
>> directory
>> It looks like the second partition is not present.
>> Sebastian Huber, embedded brains GmbH
>> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
>> Phone : +49 89 18 90 80 79-6
>> Fax : +49 89 18 90 80 79-9
>> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> ______________________________**_________________
>> rtems-users mailing list
>> rtems-users at rtems.org
>> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20121114/5f473be9/attachment.html>
