nanosleep blocks inifinity (internal rtems deathlock?) even CPU is in idle Task
Thu Nov 15 10:52:35 UTC 2012
On 11/15/2012 10:44 AM, Matthias Goldhoorn wrote:
> Hello Again,
> new Problem i got the debugger working (will port it later to the wiki, needed
> adaptations for the compiler and mentioned scripts).
> It seems there is an bugg inside of rtems. My Code calls nanosleep and never
> returnes from there.
> My main-cread is idling, so there is no higher priority process running. I
> wonder why my thread which has called nanosleep never returns...
> Any suggestions?
Do you have a clock driver configured, e.g.
#define CONFIGURE_INIT
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#include <rtems/confdefs.h>
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
