nanosleep blocks inifinity (internal rtems deathlock?) even CPU is in idle Task
Matthias Goldhoorn
matthias.goldhoorn at uni-bremen.de
Fri Nov 16 07:48:20 UTC 2012
On 15.11.2012 19:45, Chris Johns wrote:
> Matthias Goldhoorn wrote:
>> On 15.11.2012 14:52, Sebastian Huber wrote:
>>> On 11/15/2012 01:26 PM, Matthias Goldhoorn wrote:
>>>> On 15.11.2012 11:52, Sebastian Huber wrote:
>>>>> On 11/15/2012 10:44 AM, Matthias Goldhoorn wrote:
>>>> Yeah it's both defined.
>>>> The nanosleep sometimes (mostly) works.
>>>> Only if some interrupts during the sleep i got this non-awaking
>>>> behavior it seems strange.
> Which interrupts are happening that cause the sleep to not wake up, ie
> the timer to not fire ?
> What concerns me with the 'rtems_posix_threads' list you posted is no
> IDLE task which leads me to think any classic threads are not listed.
> Is there something else loading the CPU ? Maybe a classic thread
> created by the BSP.
> Chris
First of all:
Questions to _Watchdog_Ticks_since_boot
the _Watchdog_Ticks_since_boot is incrementing after watch interrupt
that results of the br to rtems_clock_tick()
Question regarding to an simple example or my current setup:
i attached the RTEMS initialization classes for my base-system. The
whole rest is rock standard, but i don't have an out of the box
bootstrap or simple example because i glued rock and rtems together.
I currently working by side of this problem to integrate the whole RTEMs
think into ROCK itself as an clean bootstrap. If i finished this
(hopefully in the next days) i could send you the link howto bootstrap this.
This might then also be interesting for RTEMs users that to Robot
control in general. But i got offtopic...
Questions to another bsp:
Not yet
Regarding to the missing idle thread:
I think this idle function is only directly called from the scheduler
and not an "real" rtems thread or thread?!
To the point no source lines available:
I dont know why GDB could not figure out the code inside of the clock
interrupt function for everything expect this function i have code lines...
Current State:
I currently try to debug more into the scheduling from rtems_clock_tick
on...
Matthias
Dipl.-Inf. Matthias Goldhoorn
Space and Underwater Robotic
Universität Bremen
FB 3 - Mathematik und Informatik
AG Robotik
Robert-Hooke-Straße 5
28359 Bremen, Germany
Tel.: +49 421 178 45-4193
Zentrale: +49 421 178 45-6550
Fax: +49 421 178 45-4150
E-Mail: matthias.goldhoorn at uni-bremen.de
Weitere Informationen: http://www.informatik.uni-bremen.de/robotik
Type: text/x-chdr
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20121116/3ca760c4/attachment.bin>
Type: text/x-chdr
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20121116/3ca760c4/attachment-0001.bin>
Type: text/x-c++src
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20121116/3ca760c4/attachment-0002.bin>
Type: text/x-c++src
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20121116/3ca760c4/attachment-0003.bin>
