leon3 console driver output processing
Ajish Babu babu.ajish at googlemail.com
Mon Nov 19 14:02:59 UTC 2012
I am using the console driver. So it should be somewhere in the termios.
Ajish
On 11/19/2012 03:00 PM, Cláudio Silva wrote:
> That seems something on the protocol level... Are you using the
> Console or APBuart directly?
> I don't think the driver is doing it, maybe termios...
> A quick google search finds that those are PPP escape characters.
> Cláudio
> On Mon, Nov 19, 2012 at 1:00 PM, Ajish Babu <babu.ajish at googlemail.com> wrote:
>> Hello Claudio,
>> Thanks a lot ... Half of the problem is fixed now. '\n' is not appended with
>> '\r' anymore.
>> But I still have the problem that 0x7D is appended with 0x5D or 0x5E. Where
>> is this happening? How do I diable it?
>> regards
>> Ajish
>> On 11/19/2012 12:46 PM, Cláudio Silva wrote:
>>> Hello, Ajish,
>>> Sorry, that documentation is for Gaisler's RTEMS version that is not
>>> yet merged to RTEMS and has the driver manager.
>>> You can find the older documentation here:
>>> http://gaisler.com/anonftp/rcc/doc/rtems-gaisler-drivers-1.0.2.pdf
>>> You will need to register the apbuart driver using:
>>> "apbuart_register(&amba_conf)" as described in the above document.
>>> Using the apbuart driver concurrently with the regular console
>>> (printf...) may lead to problems....
>>> Alternatively, you can edit the console code so it stops appending the
>>> '\r'. I think you can do so by editing the following file:
>>> https://github.com/RTEMS/rtems/blob/master/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
>>> and changing the line 146 from "apbuart_outbyte_polled(dbg_uart, c, 1,
>>> 1);" to "apbuart_outbyte_polled(dbg_uart, c, 0, 1);"
>>> Regards,
>>> Cláudio
>>> On Mon, Nov 19, 2012 at 11:21 AM, Ajish Babu <babu.ajish at googlemail.com>
>>> wrote:
>>>> Hello,
>>>> Claudio ... thanks for your response.
>>>> I still can't get it to work. I tried int fd = open("/dev/apbuart0",
>>>> O_RDWR)
>>>> with different uart numbers, but it could not find anything. According to
>>>> the driver documentation, I should use the driver-manager, but
>>>> <drvmgr/drvmgr_confdefs.h> is not found.
>>>> How can I enable this apbuart driver? I am using rtems version 4.11.
>>>> regards
>>>> Ajish
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.org
>>>> http://www.rtems.org/mailman/listinfo/rtems-users
