File system and CompactFlash question on MCF5485EVB board
Chris Xenophontos
cxenophontos at hammers.com
Fri Nov 2 14:31:24 UTC 2012
thanks Ric - I'll incorporate at next opportunity, and post back
On Fri, Nov 2, 2012 at 1:44 AM, Claus, Ric <claus at slac.stanford.edu> wrote:
> I ran into the same kind of issue but with and SD card. The problem is
> that the files you're interested in are in the first partition, not in the
> MBR area of the disk. Thus you need to dereference the first partition
> descriptor found in the MBR to find the Volume ID (see
> http://www.pjrc.com/tech/8051/ide/fat32.html), and use that to access
> your files. The following snippet of
> $RTEM_ROOT/src/cpukit/libmisc/fsmount/fsmount.h helped me to figure out
> what is going on:
> * The following example code tries to mount a FAT file system within a SD
> * Card. Some cards do not have a partition table so at first it tries to
> find
> * a file system inside the hole disk. If this is successful the mount
> process
> * will be aborted because the @ref RTEMS_FSTAB_OK condition is true. If
> this
> * did not work it tries to mount the file system inside the first
> partition.
> * If this fails the mount process will not be aborted (this is already the
> * last entry), but the last error status will be returned.
> * @code
> * #include <stdio.h>
> * #include <string.h>
> * #include <errno.h>
> * #include <rtems.h>
> * #include <rtems/bdpart.h>
> * #include <rtems/error.h>
> * #include <rtems/fsmount.h>
> * static const rtems_fstab_entry fstab [] = {
> * .source = "/dev/sd-card-a",
> * .target = "/mnt",
> * .type = "dosfs",
> * .options = RTEMS_FILESYSTEM_READ_WRITE,
> * .report_reasons = RTEMS_FSTAB_ANY,
> * .abort_reasons = RTEMS_FSTAB_OK
> * .source = "/dev/sd-card-a1",
> * .target = "/mnt",
> * .type = "dosfs",
> * .abort_reasons = RTEMS_FSTAB_NONE
> * static void my_mount(void)
> * rtems_status_code sc = RTEMS_SUCCESSFUL;
> * int rv = 0;
> * size_t abort_index = 0;
> * sc = rtems_bdpart_register_from_disk("/dev/sd-card-a");
> * if (sc != RTEMS_SUCCESSFUL) {
> * printf("read partition table failed: %s\n", rtems_status_text(sc));
> * rv = rtems_fsmount(fstab, sizeof(fstab) / sizeof(fstab [0]),
> &abort_index);
> * if (rv != 0) {
> * printf("mount failed: %s\n", strerror(errno));
> * printf("mount aborted at %zu\n", abort_index);
> * @endcode
> Cheers,
> Ric
> ________________________________________
> From: rtems-users-bounces at rtems.org [rtems-users-bounces at rtems.org] On
> Behalf Of Chris Xenophontos [cxenophontos at hammers.com]
> Sent: Thursday, November 01, 2012 8:02 PM
> To: rtems-users at rtems.org
> Subject: File system and CompactFlash question on MCF5485EVB board
> We are currently running RTEMS 4.10.2 on a Coldfire MCF5485EVB board, with
> a Transcend 4GB Compact Flash Card installed in respective slot. The
> required manufacturer's firmware has been downloaded onto CPLD in order to
> access Compact Flash, etc.
> The Compact Flash socket is wired on the board to use 16-bit accesses,
> (both enables tied together), and memory mapped mode only.
> We want to use the Compact Flash card for file storage for our
> application, not for bootup.
> I've modified an existing ATA/IDE driver to access Compact Flash card, as
> directed in RTEMS File System documentation.
> The ATA driver initializes and reads Compact Flash card status correctly,
> and, when Identify Drive command is sent to card, the correct expected data
> is returned. First word is 0x848A, and driver correctly interprets
> cylinder/head/sector and LBA info - since these values translate into the
> card's capacity of 4GB. Logical Block Addressing is used.
> The problem we have is, during register and mount process, the file system
> attempts to read an MBR from the Compact Flash card - however, all zeroes
> are returned, and the process fails.
> When a file is written to CompactFlash card using a PC, it can be listed,
> etc, so the card appears to be OK. And because the Identify Device command
> causes the card to return expected data, the HW interface from our Coldfire
> board appears to be OK as well.
> Relevant parts from rtems.c are included below - any help is greatly
> appreciated!!
> thanks
> Chris Xenophontos
> #include <stdlib.h>
> #include <rtems.h>
> #include <bsp.h>
> #include <unistd.h>
> #include <rtems/rtems_bsdnet.h>
> #include <rtems/libio.h>
> #include <rtems/shellconfig.h> // added for shell/filesystem support
> #include <rtems/ide_part_table.h>
> #include "networkconfig.h"
> #include <libchip/ide_ctrl_cfg.h>
> #include <libchip/ide_ctrl_io.h>
> #include <libchip/ata.h>
> #include <rtems/dosfs.h>
> rtems_task Init( rtems_task_argument ignored );
> extern int xmain( void );
> fstab_t fs_table[] =
> "/dev/hda","/mnt/cf", "dosfs",
> FSMOUNT_MNT_OK | FSMOUNT_MNTPNT_CRTERR | FSMOUNT_MNT_FAILED,
> 0
> rtems_status_code sc;
> int rv;
> size_t abort_index;
> abort_index = 0;
> sc = rtems_bdpart_register_from_disk( "/dev/hda" );
> rv = rtems_fsmount( fs_table, sizeof(fs_table)/sizeof(fs_table[0]),
> NULL);
> printf( "\n\nrtems_bdpart_register_from_disk status: %d\n", sc );
> // returns 27 = IO_ERROR
> printf( "\nrtems_fsmount status status: %d\n", rv );
> // return 0
> sc = rtems_shell_init ( "fstst", 60 * 1024, 150, "/dev/console", 0, 1,
> 0 );
> printf( "\nEntering xmain....\n" );
> xmain();
> #define TASK_INTLEVEL 0
> #define CONFIGURE_INIT
> #define CONFIGURE_INIT_TASK_ATTRIBUTES ( RTEMS_FLOATING_POINT |
> RTEMS_PREEMPT | RTEMS_NO_TIMESLICE | RTEMS_ASR |
> RTEMS_INTERRUPT_LEVEL(TASK_INTLEVEL))
> #define CONFIGURE_MAXIMUM_TASKS 20
> /*( SYS_MAX_TASKS + 7 ) */
> #define CONFIGURE_MAXIMUM_TIMERS 3
> #define CONFIGURE_MAXIMUM_SEMAPHORES 20 //12 // 16
> #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES 24 //SB_MAX_PIPES=23
> //32
> /* #define CONFIGURE_INIT_TASK_STACK_SIZE 2048 */
> #define CONFIGURE_INIT_TASK_STACK_SIZE (10*1024)
> #define CONFIGURE_INIT_TASK_PRIORITY 120
> #define CONFIGURE_INIT_TASK_INITIAL_MODES (RTEMS_PREEMPT | \
> RTEMS_NO_TIMESLICE | \
> RTEMS_NO_ASR | \
> RTEMS_INTERRUPT_LEVEL(0))
> #define ADA_TASKS 0
> #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> #define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> #define CONFIGURE_MAXIMUM_DRIVERS 10
> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> #define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
> #define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 30
> #define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
> #define CONFIGURE_FILESYSTEM_DOSFS
> #define CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
> #define CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
> #define CONFIGURE_ATA_DRIVER_TASK_PRIORITY 9
> #define CONFIGURE_BDBUF_MAX_WRITE_BLOCKS 512
> #define CONFIGURE_MICROSECONDS_PER_TICK 10000
> #define CONFIGURE_SHELL_COMMANDS_INIT // added for
> #define CONFIGURE_SHELL_COMMANDS_ALL // added for shell/filesystem
> support
> #include <rtems/confdefs.h>
URL: <http://lists.rtems.org/pipermail/users/attachments/20121102/fb05d5e3/attachment-0001.html>
