Read-write configuration data
Sebastian Huber
Fri Nov 9 09:01:14 UTC 2012
On 11/09/2012 04:00 AM, Mick Davis wrote:
> How do you mean read-only?
> That seems to be too broad a question to answer definitively.
Currently we have:
config_type config = { VAL1, VAL2, ..., VALN };
With read-only I mean:
const config_type config = { VAL1, VAL2, ..., VALN };
The configuration is initialized statically (e.g. via confdefs.h) and can
reside in read-only memory (e.g. flash or MMU protected RAM).
> It would seem fine for the simple self-contained RTEMS + single app case.
> But where RTEMS fits for us is with flexible devices, where there's a lot of
> runtime configuration during RTEMS start up, and loadable modules.
Most of these values will be only evaluated in
rtems_initialize_data_structures(). The only BSP specific routines that are
used before this point are the low-level startup, bsp_start(), and
bsp_work_area_initialize(). If they alter the configuration, then this is a
hack and we should find an alternative.
> Hopefully RTEMS will get an elf loader in the future and this will be true more
> generally.
> So for instance, I specifically setup rtems_telnetd_maximum_ptys from a
> configuration at runtime, depending on what else is configured.
Ok, this value is evaluated during driver initialization. So it should remain
read-write.
> In the most recent apps I've been using the unlimited system for the number of
> tasks + queues etc. But I can easily imagine going back to a system of setting
> up the Configuration_RTEMS_API before RTEMS starts with the number of resources
> based on an installed config.
Here a read-only configuration does no harm.
> Device_drivers seems like something that would often get setup depending on
> available hardware.
How does this work? Can you give me a code example? This could be a problem
now since Configuration is already read-only.
http://git.rtems.org/rtems/commit/?id=ae4f125e86f8e824d0cbb0237c1c6762d70460d8
> The location and size of the heap is setup by the bootloader for us, after all
> images have been put into memory.
The work area initialization changed recently. Please have a look at:
http://rtems.org/onlinedocs/doc-current/share/rtems/html/bsp_howto/bsp_howto_40.html#Initialization-Code-boot_005fcard_0028_0029-_002d-Boot-the-Card
> On the other hand, I have sometimes wondered if fixing the tick length would
> help performance.
The tick length is actually fix.
> I guess I don't know exactly what you plan. And it might be OK if they're just
> read only after RTEMS is up and running, perhaps using the MMU. But yes, in
> general, I would probably have an objection.
> On 08/11/12 23:48, Sebastian Huber wrote:
>> Hello,
>> a lot of the RTEMS configuration is read-write data.
>> Configuration_POSIX_API
>> Device_drivers
>> _POSIX_Threads_Initialize_user_threads_p
>> rtems_fs_init_helper
>> rtems_libio_init_helper
>> rtems_libio_number_iops
>> rtems_libio_supp_helper
>> rtems_malloc_dirty_helper
>> RTEMS_Malloc_Heap
>> rtems_malloc_statistics_helpers
>> rtems_maximum_priority
>> rtems_minimum_stack_size
>> _RTEMS_tasks_Initialize_user_tasks_p
>> _Scheduler
>> Are there objections to make them read-only?
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
