File system and CompactFlash question on MCF5485EVB board
Chris Xenophontos
cxenophontos at hammers.com
Wed Nov 14 14:26:54 UTC 2012
Yes, /dev/hda2 also. Also the Compact Flash card is formatted as FAT32.
Could this be the problem?
On Wed, Nov 14, 2012 at 2:35 AM, Sebastian Huber <
> On 11/13/2012 06:10 PM, Chris Xenophontos wrote:
>> Return codes are zero for both rtems_bdpart_register_from_**disk() and
>> rtems_fsmount(). Previously, returned 27 when we had driver problems.
>> I know that /dev/hda1 is created.
> Yes, but what about "dev/hda2"? You mentioned this error:
> fsmount: mounting of "/dev/hda2" to "/mnt/hda2" failed: No such file or
> directory
> It looks like the second partition is not present.
> Address : Obere Lagerstr. 30, D-82178 Puchheim, Germany
> Phone : +49 89 18 90 80 79-6
> Fax : +49 89 18 90 80 79-9
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
URL: <http://lists.rtems.org/pipermail/users/attachments/20121114/c22f3b1e/attachment-0001.html>
