nanosleep blocks inifinity (internal rtems deathlock?) even CPU is in idle Task
Matthias Goldhoorn
matthias.goldhoorn at uni-bremen.de
Thu Nov 15 12:26:38 UTC 2012
On 15.11.2012 11:52, Sebastian Huber wrote:
> On 11/15/2012 10:44 AM, Matthias Goldhoorn wrote:
>> Hello Again,
>> new Problem i got the debugger working (will port it later to the
>> wiki, needed
>> adaptations for the compiler and mentioned scripts).
>> It seems there is an bugg inside of rtems. My Code calls nanosleep
>> and never
>> returnes from there.
>> My main-cread is idling, so there is no higher priority process
>> running. I
>> wonder why my thread which has called nanosleep never returns...
>> Any suggestions?
> Do you have a clock driver configured, e.g.
> #define CONFIGURE_INIT
> #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> #include <rtems/confdefs.h>
Yeah it's both defined.
The nanosleep sometimes (mostly) works.
Only if some interrupts during the sleep i got this non-awaking behavior
it seems strange.
Maybe broke my memory or stack anywhere. Could you tell me where the
scheduler of rtems is located to that i can define a breakpoint into him
and check why my thread is not waked up.
I searching the timer interrupt function that really does the thread
management.
Matthias
Dipl.-Inf. Matthias Goldhoorn
Space and Underwater Robotic
Universität Bremen
FB 3 - Mathematik und Informatik
AG Robotik
Robert-Hooke-Straße 5
28359 Bremen, Germany
Tel.: +49 421 178 45-4193
Zentrale: +49 421 178 45-6550
Fax: +49 421 178 45-4150
E-Mail: matthias.goldhoorn at uni-bremen.de
Weitere Informationen: http://www.informatik.uni-bremen.de/robotik
