multiple definition of...
Sebastian Huber
Fri Nov 16 10:32:25 UTC 2012
On 11/16/2012 10:11 AM, Luca Cinquepalmi wrote:
> Hi all,
> I'm trying to compile an RTEMS application with two source file: a init.c and a
> task.c. I also have a system.h as indicated in RTEMS examples. If I use
> *#include "system.h"* in all two C files, when I compile the application, a lot
> of errors appear, all of type: *multiple definition of
> `rtems_libio_init_helper'*, ...
> All rtems examples are done in this way... how can I solve it? Thanks a lot!
> Luca
> PS: If I compile the application whit a unique file it perfectly works...
System configuration in RTEMS is performed by <rtems/confdefs.h> which uses
various application defined pre-processor defines. The actual configuration
structures are defined if CONFIGURE_INIT is defined before the include of
<rtems/confdefs.h>. You must define CONFIGURE_INIT and inlude
<rtems/confdefs.h> at most once.
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
