leon3 console driver output processing
Cláudio Silva claudiodcsilva at gmail.com
Sat Nov 17 17:00:50 UTC 2012
Hi,
It depends on which driver is active.
Probably you want to check page 135 of this document:
http://gaisler.com/anonftp/rcc/doc/rtems-gaisler-drivers-1.1.99.13.0.pdf
I think you need to call ioctl with SET_ASCII_MODE to disable the
driver's ASCII mode.
Regards,
Cláudio
On Sat, Nov 17, 2012 at 4:39 PM, Ajish Babu <babu.ajish at googlemail.com> wrote:
> Hello all,
> i am trying to use the rtems console driver for LEON3 in raw mode. I turn off all the output processing. But it still appends '\n' with '\r'  and 0x7D with 0x5D or 0x5E. Does anybody know how to disable it?
> regards
> Ajish
> rtems-users mailing list
> rtems-users at rtems.org
