leon3 console driver output processing
Espúreo Fernandez-Ulloa estados_espureos at yahoo.com.ar
Mon Nov 19 15:13:31 UTC 2012
Hello Ajish,
  I also passed through a similar issue some time ago. I currently have RTEMS 4.10 with the RCC-1.2.2 version installed.
  In case you find it useful, here are part of my config:
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
    int dev_fd;
    struct termiosnewTerm;
   /* Opening Communication devices (/dev/console_x) */
   dev_fd = open("/dev/console", O_RDWR);
   /* Get current configuration */
   tcgetattr(dev_fd, &newTerm);
   newTerm.c_lflag &= ~(ICANON|ECHO|ECHOE|ECHOK|ECHONL|ECHOPRT|ECHOCTL|ECHOKE|IEXTEN|ISIG);
   /* Local mode and receiver enabled */
   newTerm.c_cflag |= (CLOCAL | CREAD);
   /* 8 bits, enable receiver */
   newTerm.c_cflag |= CS8;
   /* Raw output */
   newTerm.c_oflag &= ~OPOST;
   /* Ignore breaks. */
   newTerm.c_iflag =  IGNBRK;
   newTerm.c_iflag &= ~INLCR; /*input modes*/
   /* Update driver's settings */
   tcsetattr(dev_fd, TCSANOW, &newTerm);
   tcflush(dev_fd, TCIOFLUSH);
Hope it helps,
Elias
________________________________
 De: Ajish Babu <babu.ajish at googlemail.com>
Para: Cláudio Silva <claudiodcsilva at gmail.com>
CC: rtems-users at rtems.org
Enviado: lunes, 19 de noviembre de 2012 10:00
Asunto: Re: leon3 console driver output processing
Hello Claudio,
Thanks a lot ... Half of the problem is fixed now. '\n' is not appended
with '\r' anymore.
But I still have the problem that 0x7D is appended with 0x5D or 0x5E.
Where is this happening? How do I diable it?
regards
Ajish
On 11/19/2012 12:46 PM, Cláudio Silva wrote:
> Hello, Ajish,
> Sorry, that documentation is for Gaisler's RTEMS version that is not
> yet merged to RTEMS and has the driver manager.
> You can find the older documentation here:
> http://gaisler.com/anonftp/rcc/doc/rtems-gaisler-drivers-1.0.2.pdf
> You will need to register the apbuart driver using:
> "apbuart_register(&amba_conf)" as described in the above document.
> Using the apbuart driver concurrently with the regular console
> (printf...) may lead to problems....
> Alternatively, you can edit the console code so it stops appending the
> '\r'. I think you can do so by editing the following file:
> https://github.com/RTEMS/rtems/blob/master/c/src/lib/libbsp/sparc/leon3/console/printk_support.c
> and changing the line 146 from "apbuart_outbyte_polled(dbg_uart, c, 1,
> 1);" to "apbuart_outbyte_polled(dbg_uart, c, 0, 1);"
> Regards,
> Cláudio
> On Mon, Nov 19, 2012 at 11:21 AM, Ajish Babu <babu.ajish at googlemail.com> wrote:
>> Hello,
>> Claudio ... thanks for your response.
>> I still can't get it to work. I tried int fd = open("/dev/apbuart0", O_RDWR)
>> with different uart numbers, but it could not find anything. According to
>> the driver documentation, I should use the driver-manager, but
>> <drvmgr/drvmgr_confdefs.h> is not found.
>> How can I enable this apbuart driver? I am using rtems version 4.11.
>> regards
>> Ajish
>> rtems-users mailing list
>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20121119/48aef735/attachment-0001.html>
