rtems object class
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Nov 20 15:27:36 UTC 2012
On 11/20/2012 5:34 AM, Luca Cinquepalmi wrote:
> Has anybody used rtems object class (rtemsTask.cc, rtemsSemaphore.cc,
> etc)? I'm trying to use them like in /rtems/testsuites/libtests/rtems++
> folder, but if I don't add the .cc file to source to be compiled g++
> doesn't compile all the sources... Does anybody have some examples of
> how to use them? thanks a lot.
Did you add the --enable-cxx option to your configure command?
I don't recall off the top of my head if this code is placed in a
separate library
so you might have to add another library to get it linked in.
> Luca
> rtems-users mailing list
> rtems-users at rtems.org
Joel Sherrill, Ph.D. Director of Research& Development
