install path for libcpu
Tue Oct 2 14:55:50 UTC 2012
On 10/02/2012 09:38 AM, Hill, Jeff wrote:
> Hello,
> Maybe someone will have a quick answer for an RTEMS build system mystery
> that I currently don't understand. I have had to make this change in
> c/src/make/compilers/gcc-target-default.cfg but I don't understand
> why others do not experience the same issue?
> After:
> LINK_FILES =\
>      $(CONSTRUCTOR) \
>      $(OBJS) \
>      $(PROJECT_RELEASE)/lib/librtemsbsp$(LIBSUFFIX_VA) \
>      $(PROJECT_RELEASE)/../lib/librtemscpu$(LIBSUFFIX_VA)
> Before:
> LINK_FILES =\
>      $(CONSTRUCTOR) \
>      $(OBJS) \
>      $(PROJECT_RELEASE)/lib/librtemscpu$(LIBSUFFIX_VA)
> If I don't make this change then application codes like the
> netdemo will not build with the original RTEMS build system.
> This is probably self inflicted, and no-doubt has something
> to do with install path for libcpu. I see this issue in all
> versions of RTEMS, with the Nios2 BSP.
Normally the BSP specifically lists which components
from libcpu it wants. Those get included in the librtemsbsp.a.
Here is a fragment from sparc/erc32/Makefile.am to pick up
the libcpu components that BSP wants:
libbsp_a_LIBADD  = \
     ../../../libcpu/@RTEMS_CPU@/access.rel \
     ../../../libcpu/@RTEMS_CPU@/cache.rel \
     ../../../libcpu/@RTEMS_CPU@/reg_win.rel \
     ../../../libcpu/@RTEMS_CPU@/syscall.rel
libcpu objects are not directly installed. The .h files are.
> Thanks,
> Jeff
> ______________________________________________________
> Jeffrey O. Hill           Email        johill at lanl.gov
> LANL MS H820              Voice        505 665 1831
> Los Alamos NM 87545 USA   FAX          505 665 5107
> Message content: Correspondence
> rtems-users mailing list
> rtems-users at rtems.org
Joel Sherrill, Ph.D.             Director of Research&   Development
