install path for libcpu
Tue Oct 2 21:03:10 UTC 2012
On 10/2/2012 3:40 PM, Hill, Jeff wrote:
>> Normally the BSP specifically lists which components
>> from libcpu it wants. Those get included in the librtemsbsp.a.
>> libcpu objects p--- are not directly installed. The .h files are.
> I am still confused; from my perspective it appears that some
> of the RTEMS applications, for example netdemo, appear to
> explicitly reference librtemscpu.a?
> Making all in netdemo
> make[1]: Entering directory `/home/hill/nios2-rtems/rtems/rtems-git/network-demos/netdemo'
> make[1]: *** No rule to make target
> `/home/hill/install/rtems-4.11-/nios2-rtems/altera-sys-config/lib/librtemscpu.a',
>   needed by `o-optimize/netdemo.exe'.  Stop.
Hold on... librtemscpu.a is NOT libcpu. It is cpukit.
Did you do a make install after you built RTEMS?
Did you set RTEMS_MAKEFILE_PATH to reflect the ${prefix}/${target}/${BSP}?
--joel
> Thanks for your assistance,
> Jeff
>> -----Original Message-----
>> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
>> Sent: Tuesday, October 02, 2012 8:56 AM
>> To: Hill, Jeff
>> Cc: rtems-users at rtems.org
>> Subject: Re: install path for libcpu
>> On 10/02/2012 09:38 AM, Hill, Jeff wrote:
>>> Hello,
>>> Maybe someone will have a quick answer for an RTEMS build system mystery
>>> that I currently don't understand. I have had to make this change in
>>> c/src/make/compilers/gcc-target-default.cfg but I don't understand
>>> why others do not experience the same issue?
>>> After:
>>> LINK_FILES =\
>>>       $(CONSTRUCTOR) \
>>>       $(OBJS) \
>>>       $(PROJECT_RELEASE)/lib/librtemsbsp$(LIBSUFFIX_VA) \
>>>       $(PROJECT_RELEASE)/../lib/librtemscpu$(LIBSUFFIX_VA)
>>> Before:
>>> LINK_FILES =\
>>>       $(CONSTRUCTOR) \
>>>       $(OBJS) \
>>>       $(PROJECT_RELEASE)/lib/librtemscpu$(LIBSUFFIX_VA)
>>> If I don't make this change then application codes like the
>>> netdemo will not build with the original RTEMS build system.
>>> This is probably self inflicted, and no-doubt has something
>>> to do with install path for libcpu. I see this issue in all
>>> versions of RTEMS, with the Nios2 BSP.
>> Here is a fragment from sparc/erc32/Makefile.am to pick up
>> the libcpu components that BSP wants:
>> libbsp_a_LIBADD  = \
>>       ../../../libcpu/@RTEMS_CPU@/access.rel \
>>       ../../../libcpu/@RTEMS_CPU@/cache.rel \
>>       ../../../libcpu/@RTEMS_CPU@/reg_win.rel \
>>       ../../../libcpu/@RTEMS_CPU@/syscall.rel
>> libcpu objects are not directly installed. The .h files are.
>>> Thanks,
>>> Jeff
>>> ______________________________________________________
>>> Jeffrey O. Hill           Email        johill at lanl.gov
>>> LANL MS H820              Voice        505 665 1831
>>> Los Alamos NM 87545 USA   FAX          505 665 5107
>>> Message content: Correspondence
>>> rtems-users mailing list
>>> http://www.rtems.org/mailman/listinfo/rtems-users
>> Joel Sherrill, Ph.D.             Director of Research&   Development
>> joel.sherrill at OARcorp.com        On-Line Applications Research
>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>       Support Available             (256) 722-9985
