install path for libcpu
Hill, Jeff johill at lanl.gov
Tue Oct 2 21:09:09 UTC 2012
> Did you do a make install after you built RTEMS?
> Did you set RTEMS_MAKEFILE_PATH to reflect the ${prefix}/${target}/${BSP}?
Yes, my build script does perform both of the above actions,
each time that it runs.
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: Tuesday, October 02, 2012 3:03 PM
> To: Hill, Jeff
> Cc: rtems-users at rtems.org
> Subject: Re: install path for libcpu
> On 10/2/2012 3:40 PM, Hill, Jeff wrote:
> >> Normally the BSP specifically lists which components
> >> from libcpu it wants. Those get included in the librtemsbsp.a.
> >> libcpu objects p--- are not directly installed. The .h files are.
> > I am still confused; from my perspective it appears that some
> > of the RTEMS applications, for example netdemo, appear to
> > explicitly reference librtemscpu.a?
> > Making all in netdemo
> > make[1]: Entering directory `/home/hill/nios2-rtems/rtems/rtems-
> git/network-demos/netdemo'
> > make[1]: *** No rule to make target
> > `/home/hill/install/rtems-4.11-/nios2-rtems/altera-sys-
> config/lib/librtemscpu.a',
> >   needed by `o-optimize/netdemo.exe'.  Stop.
> Hold on... librtemscpu.a is NOT libcpu. It is cpukit.
> --joel
> > Thanks for your assistance,
> > Jeff
> >> Sent: Tuesday, October 02, 2012 8:56 AM
> >> To: Hill, Jeff
> >> On 10/02/2012 09:38 AM, Hill, Jeff wrote:
> >>> Hello,
> >>> Maybe someone will have a quick answer for an RTEMS build system
> mystery
> >>> that I currently don't understand. I have had to make this change in
> >>> c/src/make/compilers/gcc-target-default.cfg but I don't understand
> >>> why others do not experience the same issue?
> >>> After:
> >>> LINK_FILES =\
> >>>       $(CONSTRUCTOR) \
> >>>       $(OBJS) \
> >>>       $(PROJECT_RELEASE)/lib/librtemsbsp$(LIBSUFFIX_VA) \
> >>>       $(PROJECT_RELEASE)/../lib/librtemscpu$(LIBSUFFIX_VA)
> >>> Before:
> >>> LINK_FILES =\
> >>>       $(CONSTRUCTOR) \
> >>>       $(OBJS) \
> >>>       $(PROJECT_RELEASE)/lib/librtemscpu$(LIBSUFFIX_VA)
> >>> If I don't make this change then application codes like the
> >>> netdemo will not build with the original RTEMS build system.
> >>> This is probably self inflicted, and no-doubt has something
> >>> to do with install path for libcpu. I see this issue in all
> >>> versions of RTEMS, with the Nios2 BSP.
> >> Here is a fragment from sparc/erc32/Makefile.am to pick up
> >> the libcpu components that BSP wants:
> >> libbsp_a_LIBADD  = \
> >>       ../../../libcpu/@RTEMS_CPU@/access.rel \
> >>       ../../../libcpu/@RTEMS_CPU@/cache.rel \
> >>       ../../../libcpu/@RTEMS_CPU@/reg_win.rel \
> >>       ../../../libcpu/@RTEMS_CPU@/syscall.rel
> >> libcpu objects are not directly installed. The .h files are.
> >>> Thanks,
> >>> Jeff
> >>> ______________________________________________________
> >>> Jeffrey O. Hill           Email        johill at lanl.gov
> >>> LANL MS H820              Voice        505 665 1831
> >>> Los Alamos NM 87545 USA   FAX          505 665 5107
> >>> Message content: Correspondence
> >>> rtems-users mailing list
> >>> http://www.rtems.org/mailman/listinfo/rtems-users
> >> Joel Sherrill, Ph.D.             Director of Research&   Development
> >> joel.sherrill at OARcorp.com        On-Line Applications Research
> >> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> >>       Support Available             (256) 722-9985
