install path for libcpu
Hill, Jeff johill at lanl.gov
Tue Oct 2 22:22:10 UTC 2012
> How did you configure? The ones I have are from configuring like this:
> ../rtems/configure --target=<CPU>-rtems4.11 --enable-rtemsbsp=<BSP> \
>     --prefix=<prefix>
My build script is as follows (note that I don't have
--enable-rtemsbsp=<BSP>, as you have specifically
called out, opting instead to use "make RTEMS_BSP=$BSP" ).
BSP=altera-sys-config
TARGET=nios2-rtems
if $RECONFIG_RTEMS; then
    cd $HOME/build
    rm -rf    b-rtems
    mkdir -p  b-rtems
    cd        b-rtems
    $RTEMS/configure \
    --target=$TARGET\
    --prefix=$PREFIX \
    --disable-itron \
    --enable-posix \
    --enable-cxx \
    --enable-multilib \
    --enable-networking \
    --enable-tests=samples \
    --enable-maintainer-mode
    if test $? != 0; then
        exit -1
    fi
    cd $BASEDIR
fi
# MAKE RTEMS ###############################################
if $REMAKE_RTEMS; then
    cd $HOME/build
    cd b-rtems
    make V=100 \
        RTEMS_BSP="" \
        VARIANT="$RTEMS_VARIANT" \
        all
        exit -1
    fi
    make RTEMS_BSP="" \
        install
        exit -1
    fi
    cd $BASEDIR
fi
# MAKE BSP #################################################
if $REMAKE_BSP; then
    cd $HOME/build
    cd b-rtems
    make V=100\
        RTEMS_BSP=$BSP \
        ALTERA_SOPCINFO_FILE="$ALTERA_SOPCINFO"\
        all
        exit -1
    fi
    make RTEMS_BSP=$BSP \
        install
        exit -1
    fi
    cd $BASEDIR
fi
> -----Original Message-----
> From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
> Sent: Tuesday, October 02, 2012 4:09 PM
> To: Hill, Jeff
> Cc: rtems-users at rtems.org
> Subject: Re: install path for libcpu
> On 10/2/2012 4:57 PM, Hill, Jeff wrote:
> > Thanks for that explanation.
> >> If librtemscpu.a is installed properly in
> >> ${prefix}/${target}/${BSP}/lib/
> > This appears to be the root of the problem.
> > I see this file:
> > ${prefix}/${target}/lib/librtemcpu.a
> > I don't see this file:
> > ${prefix}/${target}/${BSP}/lib/librtemcpu.a
> > Removing ${prefix}/${target}/lib/librtemcpu.a and then
> > rebuilding everything doesn't improve my situation.
> > So presumably this issue, installation of librtemcpu.a on the
> > wrong path, is caused by some configuration mistake in the
> > BSP? I will have a look, but any hints are greatly
> > appreciated :-)
>     --prefix=<prefix>
> > Jeff
> >> Sent: Tuesday, October 02, 2012 3:18 PM
> >> To: Hill, Jeff
> >> On 10/2/2012 4:09 PM, Hill, Jeff wrote:
> >>>> Did you do a make install after you built RTEMS?
> >>>> Did you set RTEMS_MAKEFILE_PATH to reflect the
> >> ${prefix}/${target}/${BSP}?
> >>> Yes, my build script does perform both of the above actions,
> >>> each time that it runs.
> >> Something is subtly wrong. You shouldn't have to edit
> >> gcc-target-default.cfg and I think that's where the dependency is
> >> coming from.
> >> librtemscpu.a is normally picked up by adding -qrtems to the gcc
> >> command line. This dependency is built into gcc if the target is
> >> built to include gcc/config/rtems.h. This is from gcc/config.gcc
> >> for the mips target.
> >> mips*-*-rtems*)
> >>           tm_file="elfos.h newlib-stdint.h ${tm_file} mips/elf.h
> >> mips/rtems.h rtems.h"
> >>           tmake_file="mips/t-elf t-rtems mips/t-rtems"
> >> Notice that tm_file references rtems.h which corresponds to
> >> gcc/config/rtems.h
> >> and that file has this:
> >> #undef LIB_SPEC
> >> #define LIB_SPEC "%{!qrtems: " STD_LIB_SPEC "} " \
> >> "%{!nostdlib: %{qrtems: --start-group \
> >>    -lrtemsbsp -lrtemscpu \
> >>    -lc -lgcc --end-group %{!qnolinkcmds: -T linkcmds%s}}}"
> >> Which is how the -lrtemscpu is picked up.
> >> ${prefix}/${target}/${BSP}/lib, then
> >> the gcc built-in library specification should let you find it.
> >> Time to check what gcc is doing.
> >>>> Sent: Tuesday, October 02, 2012 3:03 PM
> >>>> To: Hill, Jeff
> >>>> On 10/2/2012 3:40 PM, Hill, Jeff wrote:
> >>>>>> Normally the BSP specifically lists which components
> >>>>>> from libcpu it wants. Those get included in the librtemsbsp.a.
> >>>>>> libcpu objects p--- are not directly installed. The .h files are.
> >>>>> I am still confused; from my perspective it appears that some
> >>>>> of the RTEMS applications, for example netdemo, appear to
> >>>>> explicitly reference librtemscpu.a?
> >>>>> Making all in netdemo
> >>>>> make[1]: Entering directory `/home/hill/nios2-rtems/rtems/rtems-
> >>>> git/network-demos/netdemo'
> >>>>> make[1]: *** No rule to make target
> >>>>> `/home/hill/install/rtems-4.11-/nios2-rtems/altera-sys-
> >>>> config/lib/librtemscpu.a',
> >>>>>     needed by `o-optimize/netdemo.exe'.  Stop.
> >>>> Hold on... librtemscpu.a is NOT libcpu. It is cpukit.
> >>>> --joel
> >>>>> Thanks for your assistance,
> >>>>> Jeff
> >>>>>> Sent: Tuesday, October 02, 2012 8:56 AM
> >>>>>> To: Hill, Jeff
> >>>>>> On 10/02/2012 09:38 AM, Hill, Jeff wrote:
> >>>>>>> Hello,
> >>>>>>> Maybe someone will have a quick answer for an RTEMS build system
> >>>> mystery
> >>>>>>> that I currently don't understand. I have had to make this change
> in
> >>>>>>> c/src/make/compilers/gcc-target-default.cfg but I don't understand
> >>>>>>> why others do not experience the same issue?
> >>>>>>> After:
> >>>>>>> LINK_FILES =\
> >>>>>>>         $(CONSTRUCTOR) \
> >>>>>>>         $(OBJS) \
> >>>>>>>         $(PROJECT_RELEASE)/lib/librtemsbsp$(LIBSUFFIX_VA) \
> >>>>>>>         $(PROJECT_RELEASE)/../lib/librtemscpu$(LIBSUFFIX_VA)
> >>>>>>> Before:
> >>>>>>> LINK_FILES =\
> >>>>>>>         $(CONSTRUCTOR) \
> >>>>>>>         $(OBJS) \
> >>>>>>>         $(PROJECT_RELEASE)/lib/librtemscpu$(LIBSUFFIX_VA)
> >>>>>>> If I don't make this change then application codes like the
> >>>>>>> netdemo will not build with the original RTEMS build system.
> >>>>>>> This is probably self inflicted, and no-doubt has something
> >>>>>>> to do with install path for libcpu. I see this issue in all
> >>>>>>> versions of RTEMS, with the Nios2 BSP.
> >>>>>> Here is a fragment from sparc/erc32/Makefile.am to pick up
> >>>>>> the libcpu components that BSP wants:
> >>>>>> libbsp_a_LIBADD  = \
> >>>>>>         ../../../libcpu/@RTEMS_CPU@/access.rel \
> >>>>>>         ../../../libcpu/@RTEMS_CPU@/cache.rel \
> >>>>>>         ../../../libcpu/@RTEMS_CPU@/reg_win.rel \
> >>>>>>         ../../../libcpu/@RTEMS_CPU@/syscall.rel
> >>>>>> libcpu objects are not directly installed. The .h files are.
> >>>>>>> Thanks,
> >>>>>>> Jeff
> >>>>>>> ______________________________________________________
> >>>>>>> Jeffrey O. Hill           Email        johill at lanl.gov
> >>>>>>> LANL MS H820              Voice        505 665 1831
> >>>>>>> Los Alamos NM 87545 USA   FAX          505 665 5107
> >>>>>>> Message content: Correspondence
> >>>>>>> rtems-users mailing list
> >>>>>>> http://www.rtems.org/mailman/listinfo/rtems-users
> >>>>>> Joel Sherrill, Ph.D.             Director of Research&
> Development
> >>>>>> joel.sherrill at OARcorp.com        On-Line Applications Research
> >>>>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> >>>>>>         Support Available             (256) 722-9985
> >>>> Joel Sherrill, Ph.D.             Director of Research&  Development
