Error from make all & make install
James McCombs mccombsj4 at gmail.com
Thu Oct 11 01:56:21 UTC 2012
Hello,
I am building RTEMS 4.10.2 and I keep getting  "*** [all-recursive] Error
1" and "*** [install-recursive] Error 1" whenever I attempt to "make all"
or "make install." The output from running these commands is below and in
the attached .txt document. I appreciate any help or direction.
linux-hrtm:/usr/src/packages/tools/build-rtems #
/usr/src/packages/tools/rtems-4.10.2/configure --target=m68k --enable-posix
--disable-networking --disable-cxx --enable-rtemsbsp=uC5282
--prefix=/opt/rtems-4.10
configure: loading site script /usr/share/site/i686-pc-linux-gnu
checking for gmake... gmake
checking for RTEMS Version... 4.10.2
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... m68k-unknown-none
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether gmake sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
configure: creating ./config.status
configure: configuring in ./tools/build
configure: running /bin/sh
'/usr/src/packages/tools/rtems-4.10.2/tools/build/configure'
'--prefix=/opt/rtems-4.10' '--host=i686-pc-linux-gnu'
'--build=i686-pc-linux-gnu'  '--enable-posix' '--disable-networking'
'--disable-cxx' '--enable-rtemsbsp=uC5282' '--target=m68k'
 '--cache-file=/dev/null'
'--srcdir=/usr/src/packages/tools/rtems-4.10.2/tools/build'
checking for i686-pc-linux-gnu-gcc... no
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by gmake... GNU
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking for strerror... yes
checking for strtol... yes
checking for bash... /bin/bash
config.status: creating Makefile
config.status: creating install-if-change
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
configure: configuring in ./tools/cpu
'/usr/src/packages/tools/rtems-4.10.2/tools/cpu/configure'
'--srcdir=/usr/src/packages/tools/rtems-4.10.2/tools/cpu'
checking rtems target cpu... m68k
=== configuring in generic
(/usr/src/packages/tools/build-rtems/tools/cpu/generic)
/usr/src/packages/tools/rtems-4.10.2/tools/cpu/generic/configure
--disable-option-checking '--prefix=/opt/rtems-4.10'
 '--host=i686-pc-linux-gnu' '--build=i686-pc-linux-gnu' '--enable-posix'
'--disable-networking' '--disable-cxx' '--enable-rtemsbsp=uC5282'
'--target=m68k' 'build_alias=i686-pc-linux-gnu'
'host_alias=i686-pc-linux-gnu' 'target_alias=m68k' --cache-file=/dev/null
--srcdir=/usr/src/packages/tools/rtems-4.10.2/tools/cpu/generic
config.status: creating size_rtems
configure: configuring in ./testsuites/tools
'/usr/src/packages/tools/rtems-4.10.2/testsuites/tools/configure'
'--srcdir=/usr/src/packages/tools/rtems-4.10.2/testsuites/tools'
(/usr/src/packages/tools/build-rtems/testsuites/tools/generic)
/usr/src/packages/tools/rtems-4.10.2/testsuites/tools/generic/configure
--srcdir=/usr/src/packages/tools/rtems-4.10.2/testsuites/tools/generic
config.status: creating difftest
config.status: creating sorttimes
configure: configuring in m68k/c
'/usr/src/packages/tools/rtems-4.10.2/c/configure'
'--prefix=/opt/rtems-4.10' '--host=m68k' '--build=i686-pc-linux-gnu'
'--target=m68k'  '--enable-posix' '--disable-networking' '--disable-cxx'
'--enable-rtemsbsp=uC5282' '--with-target-subdir=m68k'
'--exec-prefix=/opt/rtems-4.10/m68k'
'--includedir=/opt/rtems-4.10/m68k/include'  '--cache-file=/dev/null'
'--srcdir=/usr/src/packages/tools/rtems-4.10.2/c'
checking host system type... m68k-unknown-none
checking for m68k-strip... no
checking for strip... strip
configure: WARNING: using cross tools not prefixed with host triplet
target architecture: m68k.
available BSPs: uC5282.
'gmake all' will build the following BSPs: uC5282.
other BSPs can be built with 'gmake RTEMS_BSP="bsp1 bsp2 ..."'
config.status: creating make/Makefile
linux-hrtm:/usr/src/packages/tools/build-rtems # make all
Making all in make
gmake[1]: Entering directory `/usr/src/packages/tools/build-rtems/make'
gmake[1]: Nothing to be done for `all'.
gmake[1]: Leaving directory `/usr/src/packages/tools/build-rtems/make'
Making all in tools/build
`/usr/src/packages/tools/build-rtems/tools/build'
gmake  all-am
gmake[2]: Entering directory
gmake[2]: Leaving directory
Making all in tools/cpu
gmake[1]: Entering directory `/usr/src/packages/tools/build-rtems/tools/cpu'
Making all in generic
`/usr/src/packages/tools/build-rtems/tools/cpu/generic'
gmake[2]: Nothing to be done for `all'.
gmake[2]: Entering directory `/usr/src/packages/tools/build-rtems/tools/cpu'
gmake[2]: Nothing to be done for `all-am'.
gmake[2]: Leaving directory `/usr/src/packages/tools/build-rtems/tools/cpu'
gmake[1]: Leaving directory `/usr/src/packages/tools/build-rtems/tools/cpu'
Making all in testsuites/tools
`/usr/src/packages/tools/build-rtems/testsuites/tools'
`/usr/src/packages/tools/build-rtems/testsuites/tools/generic'
Making all in m68k/c
gmake[1]: Entering directory `/usr/src/packages/tools/build-rtems/m68k/c'
Making all in .
gmake[2]: Entering directory `/usr/src/packages/tools/build-rtems/m68k/c'
gmake[2]: Leaving directory `/usr/src/packages/tools/build-rtems/m68k/c'
Making all in uC5282
`/usr/src/packages/tools/build-rtems/m68k/c/uC5282'
gmake[2]: *** No rule to make target `all'.  Stop.
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory `/usr/src/packages/tools/build-rtems/m68k/c'
make: *** [all-recursive] Error 1
linux-hrtm:/usr/src/packages/tools/build-rtems # make install
Making install in make
gmake[2]: Entering directory `/usr/src/packages/tools/build-rtems/make'
gmake[2]: Nothing to be done for `install-exec-am'.
test -z "/opt/rtems-4.10/make" || /bin/mkdir -p "/opt/rtems-4.10/make"
 /usr/bin/install -c -m 644
/usr/src/packages/tools/rtems-4.10.2/make/main.cfg
/usr/src/packages/tools/rtems-4.10.2/make/leaf.cfg '/opt/rtems-4.10/make'
test -z "/opt/rtems-4.10/make/Templates" || /bin/mkdir -p
/usr/src/packages/tools/rtems-4.10.2/make/Templates/Makefile.dir
/usr/src/packages/tools/rtems-4.10.2/make/Templates/Makefile.leaf
/usr/src/packages/tools/rtems-4.10.2/make/Templates/Makefile.lib
'/opt/rtems-4.10/make/Templates'
test -z "/opt/rtems-4.10/make/custom" || /bin/mkdir -p
/usr/src/packages/tools/rtems-4.10.2/make/custom/default.cfg
'/opt/rtems-4.10/make/custom'
gmake[2]: Leaving directory `/usr/src/packages/tools/build-rtems/make'
Making install in tools/build
test -z "/opt/rtems-4.10/bin" || /bin/mkdir -p "/opt/rtems-4.10/bin"
  /usr/bin/install -c cklength eolstrip packhex unhex rtems-bin2c
'/opt/rtems-4.10/bin'
 /usr/bin/install -c install-if-change '/opt/rtems-4.10/bin'
gmake[2]: Nothing to be done for `install-data-am'.
Making install in tools/cpu
Making install in generic
gmake[3]: Entering directory
gmake[3]: Nothing to be done for `install-exec-am'.
gmake[3]: Nothing to be done for `install-data-am'.
gmake[3]: Leaving directory
gmake[3]: Entering directory `/usr/src/packages/tools/build-rtems/tools/cpu'
gmake[3]: Leaving directory `/usr/src/packages/tools/build-rtems/tools/cpu'
Making install in testsuites/tools
 /usr/bin/install -c difftest '/opt/rtems-4.10/bin/./m68k-difftest'
 /usr/bin/install -c sorttimes '/opt/rtems-4.10/bin/./m68k-sorttimes'
Making install in m68k/c
Making install in .
gmake[3]: Entering directory `/usr/src/packages/tools/build-rtems/m68k/c'
gmake[3]: Leaving directory `/usr/src/packages/tools/build-rtems/m68k/c'
Making install in uC5282
gmake[2]: *** No rule to make target `install'.  Stop.
gmake[1]: *** [install-recursive] Error 1
make: *** [install-recursive] Error 1
*James McCombs*
URL: <http://lists.rtems.org/pipermail/users/attachments/20121010/ad8ed208/attachment.html>
linux-hrtm:/usr/src/packages/tools/build-rtems # /usr/src/packages/tools/rtems-4.10.2/configure --target=m68k --enable-posix --disable-networking --disable-cxx --enable-rtemsbsp=uC5282 --prefix=/opt/rtems-4.10
configure: running /bin/sh '/usr/src/packages/tools/rtems-4.10.2/tools/build/configure' '--prefix=/opt/rtems-4.10' '--host=i686-pc-linux-gnu' '--build=i686-pc-linux-gnu'  '--enable-posix' '--disable-networking' '--disable-cxx' '--enable-rtemsbsp=uC5282' '--target=m68k'  '--cache-file=/dev/null' '--srcdir=/usr/src/packages/tools/rtems-4.10.2/tools/build'
configure: running /bin/sh '/usr/src/packages/tools/rtems-4.10.2/tools/cpu/configure' '--prefix=/opt/rtems-4.10' '--host=i686-pc-linux-gnu' '--build=i686-pc-linux-gnu'  '--enable-posix' '--disable-networking' '--disable-cxx' '--enable-rtemsbsp=uC5282' '--target=m68k'  '--cache-file=/dev/null' '--srcdir=/usr/src/packages/tools/rtems-4.10.2/tools/cpu'
=== configuring in generic (/usr/src/packages/tools/build-rtems/tools/cpu/generic)
configure: running /bin/sh /usr/src/packages/tools/rtems-4.10.2/tools/cpu/generic/configure --disable-option-checking '--prefix=/opt/rtems-4.10'  '--host=i686-pc-linux-gnu' '--build=i686-pc-linux-gnu' '--enable-posix' '--disable-networking' '--disable-cxx' '--enable-rtemsbsp=uC5282' '--target=m68k' 'build_alias=i686-pc-linux-gnu' 'host_alias=i686-pc-linux-gnu' 'target_alias=m68k' --cache-file=/dev/null --srcdir=/usr/src/packages/tools/rtems-4.10.2/tools/cpu/generic
configure: running /bin/sh '/usr/src/packages/tools/rtems-4.10.2/testsuites/tools/configure' '--prefix=/opt/rtems-4.10' '--host=i686-pc-linux-gnu' '--build=i686-pc-linux-gnu'  '--enable-posix' '--disable-networking' '--disable-cxx' '--enable-rtemsbsp=uC5282' '--target=m68k'  '--cache-file=/dev/null' '--srcdir=/usr/src/packages/tools/rtems-4.10.2/testsuites/tools'
=== configuring in generic (/usr/src/packages/tools/build-rtems/testsuites/tools/generic)
configure: running /bin/sh /usr/src/packages/tools/rtems-4.10.2/testsuites/tools/generic/configure --disable-option-checking '--prefix=/opt/rtems-4.10'  '--host=i686-pc-linux-gnu' '--build=i686-pc-linux-gnu' '--enable-posix' '--disable-networking' '--disable-cxx' '--enable-rtemsbsp=uC5282' '--target=m68k' 'build_alias=i686-pc-linux-gnu' 'host_alias=i686-pc-linux-gnu' 'target_alias=m68k' --cache-file=/dev/null --srcdir=/usr/src/packages/tools/rtems-4.10.2/testsuites/tools/generic
configure: running /bin/sh '/usr/src/packages/tools/rtems-4.10.2/c/configure' '--prefix=/opt/rtems-4.10' '--host=m68k' '--build=i686-pc-linux-gnu' '--target=m68k'  '--enable-posix' '--disable-networking' '--disable-cxx' '--enable-rtemsbsp=uC5282' '--with-target-subdir=m68k' '--exec-prefix=/opt/rtems-4.10/m68k' '--includedir=/opt/rtems-4.10/m68k/include'  '--cache-file=/dev/null' '--srcdir=/usr/src/packages/tools/rtems-4.10.2/c'
Making all in make
gmake[1]: Entering directory `/usr/src/packages/tools/build-rtems/tools/build'
gmake  all-am
gmake[2]: Entering directory `/usr/src/packages/tools/build-rtems/tools/build'
gmake[2]: Leaving directory `/usr/src/packages/tools/build-rtems/tools/build'
gmake[1]: Leaving directory `/usr/src/packages/tools/build-rtems/tools/build'
gmake[2]: Entering directory `/usr/src/packages/tools/build-rtems/tools/cpu/generic'
gmake[2]: Leaving directory `/usr/src/packages/tools/build-rtems/tools/cpu/generic'
gmake[1]: Entering directory `/usr/src/packages/tools/build-rtems/testsuites/tools'
gmake[2]: Entering directory `/usr/src/packages/tools/build-rtems/testsuites/tools/generic'
gmake[2]: Leaving directory `/usr/src/packages/tools/build-rtems/testsuites/tools/generic'
gmake[2]: Entering directory `/usr/src/packages/tools/build-rtems/testsuites/tools'
gmake[2]: Leaving directory `/usr/src/packages/tools/build-rtems/testsuites/tools'
gmake[1]: Leaving directory `/usr/src/packages/tools/build-rtems/testsuites/tools'
Making all in .
gmake[2]: Entering directory `/usr/src/packages/tools/build-rtems/m68k/c/uC5282'
gmake[2]: Leaving directory `/usr/src/packages/tools/build-rtems/m68k/c/uC5282'
 /usr/bin/install -c -m 644 /usr/src/packages/tools/rtems-4.10.2/make/main.cfg /usr/src/packages/tools/rtems-4.10.2/make/leaf.cfg '/opt/rtems-4.10/make'
test -z "/opt/rtems-4.10/make/Templates" || /bin/mkdir -p "/opt/rtems-4.10/make/Templates"
 /usr/bin/install -c -m 644 /usr/src/packages/tools/rtems-4.10.2/make/Templates/Makefile.dir /usr/src/packages/tools/rtems-4.10.2/make/Templates/Makefile.leaf /usr/src/packages/tools/rtems-4.10.2/make/Templates/Makefile.lib '/opt/rtems-4.10/make/Templates'
test -z "/opt/rtems-4.10/make/custom" || /bin/mkdir -p "/opt/rtems-4.10/make/custom"
 /usr/bin/install -c -m 644 /usr/src/packages/tools/rtems-4.10.2/make/custom/default.cfg '/opt/rtems-4.10/make/custom'
  /usr/bin/install -c cklength eolstrip packhex unhex rtems-bin2c '/opt/rtems-4.10/bin'
gmake[3]: Entering directory `/usr/src/packages/tools/build-rtems/tools/cpu/generic'
gmake[3]: Leaving directory `/usr/src/packages/tools/build-rtems/tools/cpu/generic'
gmake[3]: Entering directory `/usr/src/packages/tools/build-rtems/testsuites/tools/generic'
gmake[3]: Leaving directory `/usr/src/packages/tools/build-rtems/testsuites/tools/generic'
gmake[3]: Entering directory `/usr/src/packages/tools/build-rtems/testsuites/tools'
gmake[3]: Leaving directory `/usr/src/packages/tools/build-rtems/testsuites/tools'
Making install in .
