sparc-rtems4.11-gcc for C++
Jiri Freyvald
jiri.freyvald at gmail.com
Tue Oct 30 12:17:13 UTC 2012
IMHO you don't have to set $(ARCH) for building rtems binaries if you
have toolchain properly set.
Most of examples provided and all my application so far work ok with
standard makefile (well, at least compilation succeeded and applications
send some outputs to stdout)
( so far I tried: i386-rtems4.11/pc386 and sparc-rtems4.11/sis in sis
simulator, in qemu and on real cortex-m4 hardware)
I can send you some C++ "hello world" application with makefile if you want
Jiri
On 30/10/12 11:01, Luca Cinquepalmi wrote:
> Jiri only one question:
> where $(ARCH) is set? which file? thanks
> Luca
> On 10/30/2012 10:43 AM, Jiri Freyvald wrote:
>> Hi,
>> as I suggested in my previous reply - use existing C++ example (with
>> its makefile) as a c++ template for your project.
>> Anyway,
>> here is the output of my makefile (c++ example):
>> $ export PATH=/opt/rtems-4.11/bin:$PATH
>> $ export RTEMS_MAKEFILE_PATH=/opt/rtems-fw/sparc-rtems4.11/sis/
>> $make clean all
>> rm -f a.out core mon.out gmon.out
>> rm -f -r
>> rm -f -r a.out *.o *.BAK Depends-o-optimize.tmp
>> rm -f -r o-optimize o-debug
>> test -d o-optimize || mkdir o-optimize
>> sparc-rtems4.11-gcc --pipe -B/opt/rtems-fw/sparc-rtems4.11/sis/lib/
>> -specs bsp_specs -qrtems -g -Wall -O2 -g -g -mcpu=cypress
>> -c -o o-optimize/init.o init.c
>> sparc-rtems4.11-g++ -B/opt/rtems-fw/sparc-rtems4.11/sis/lib/ -specs
>> bsp_specs -qrtems -g -Wall -g -mcpu=cypress -c -o
>> o-optimize/main.o main.cc
>> bsp_specs -qrtems -g -Wall -g -mcpu=cypress -mcpu=cypress -o
>> o-optimize/cxx_throw.exe o-optimize/init.o o-optimize/main.o
>> sparc-rtems4.11-nm -g -n o-optimize/cxx_throw.exe >
>> o-optimize/cxx_throw.num
>> sparc-rtems4.11-size o-optimize/cxx_throw.exe
>> text data bss dec hex filename
>> 212608 2740 22960 238308 3a2e4
>> cp o-optimize/cxx_throw.exe o-optimize/cxx_throw.ralf
>> it should help you
>> Jiri
>> On 30/10/12 08:47, Luca Cinquepalmi wrote:
>>> Here I post a simple rtems C++ code (template.cc) which works if
>>> compiled as a C source file but not as a C++ file.
>>> I'm using sparc-rtems4.11-g++ compiler. Are there particular compilation
>>> flags I have to use? Is C++ template different from C one? Thanks a lot
>>> Luca
>>> #define CONFIGURE_INIT
>>> #include "system.h"
>>> #include <cstdlib>
>>> extern "C" {
>>> rtems_task Init(
>>> rtems_task_argument arg
>>> /* Declare rtems tasks */
>>> rtems_task Init (rtems_task_argument argument); /* Declare entry
>>> point */
>>> #include "define.h"
>>> #include "leon.h"
>>> #include "utils.h"
>>> #include "printSerial.h"
>>> printf("MY NAME IS LUCA!\n\r");
>>> rtems_task_delete(RTEMS_SELF);
>>> My Makefile flags:
>>> CXX = sparc-rtems4.11-g++
>>> BSP_PATH = /opt/$(INSTALL_POINT)/sparc-$(CCOMP)/leon2/lib
>>> SPECS_PATH = $(BSP_PATH)/bsp_specs
>>> LD_LIBS += -lgcc -lm -msoft-float -lrtems++ -lstdc++
>>> LD_PATH += -I../../include/leon -I../include -B$(BSP_PATH) -specs
>>> $(SPECS_PATH)
>>> LDFLAGS += -mcpu=v8 -qrtems
>>> CXXFLAGS += -msoft-float -mcpu=v8 $(LD_PATH) -Wno-write-strings
>>> rtems-users mailing list
>>> rtems-users at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20121030/b3dadb26/attachment.html>
