rtems_semaphore_delete directive RTEMS_RESOURCE_IN_USE status code
Mon Oct 1 20:56:53 UTC 2012
On 10/1/2012 2:45 PM, Andrei Dimitrief-Jianu wrote:
> Hello,
> Could someone clarify for me when rtems_semaphore_delete directive
> would return RTEMS_RESOURCE_IN_USE status code?
> My guess is that RTEMS_RESOURCE_IN_USE is returned if there are tasks
> waiting to acquire the semaphore, but the API
> document also says that:
> "All tasks blocked waiting to acquire the semaphore will be readied
> and returned a status code which
> indicates that the semaphore was deleted."
I think that that error is only returned when you have created it as a
binary semaphore
and it is locked.
And it looks like the documentation could use clarification. :(
> Regards,
> Andrei.
> rtems-users mailing list
> rtems-users at rtems.org
Joel Sherrill, Ph.D.             Director of Research&  Development
